Old 04-18-2008, 06:01 PM   #1
Car: 08 dark grey sti
Default Tire Rubbing Noise In Hard Turn
I took a couple of hard fast turns with three people in the car 3rd gear WOT. I got a horrible noise, sounds like the tires grinding the Rear wheel wells. Thought the fender and tires were going to be ripped up but cant find any sings of rubbing. I had five people in the car in a parking lot one time and had no noise. Need some input NOT GOING TO THE DEALER have to drive way to hard to hear the noise going to try it by myself but i dont think this should happen no matter how i drive. Any one have this problem?
MJKustom is offline   Reply With Quote
Old 04-18-2008, 06:15 PM   #2
Default Re: Tire Rubbing Noise In Hard Turn
I went out there again with a flash light and found that it burned up the inside mount (plastic washer) on the rally armor mud flaps. think i have to remove the spacer to get more clearence.
Old 04-19-2008, 06:19 AM   #3
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Hehe I was just coming in to post that. I had the exact same noise when turning hard. It turned out that the spacer is only supposed to be used for the alternative drill-a-hole install method. If you are just using the clip, you don't need the spacer.
Old 04-19-2008, 04:11 PM   #4
pwn
Car: WRB 08 STI
Fav Mod: Only one - Cobb AP
Send a message via AIM to pwn
If you drill and use the spacer, will you rub?
pwn is offline   Reply With Quote
Old 04-19-2008, 04:38 PM   #5
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
No because I believe you use a different hole on the flap.
