Old 06-10-2008, 11:47 AM   #31
Car: WRB 2004 WRX STi
Default Re: Weird start-up issue...
crazy. but the starter motor screech just happened to me for the first time today. I have 25K miles on the Odo. I quickly turned the key back to off then started the car up normally.
i plan to just sit back and see what develops out of it.
weird.
gbonesti is offline   Reply With Quote
Old 06-11-2008, 07:21 PM   #32
Car: 04 Audi TT 3.2
Fav Mod: Shopping for an STi
Default Re: Weird start-up issue (possibly the starter motor)...
When I went into the dealership about a year ago to test drive a new 07 STi, I heard what I would guess is the same sound you are hearing.
The salesman went to start the car and bring it around for a test drive, and I heard this horrible screeching sound on his first attempt - unlike any sound I had ever heard coming from a car. After a pause, his second attempt started the car without trouble. Despite being a bit red-faced, he dismissed the sound as "not a problem" and gave no explanation.
After hearing that sound, I quickly lost interest in that car (despite the fact I loved the test drive), although I'd still like to know what caused it.
subieroux is offline   Reply With Quote
Old 06-14-2008, 09:27 AM   #33
Car: Blue 08 WRX STi
The screech sound from the starter could be a bendix drive problem, the bendix drive when energized pushes the starter gear out to engage the flywheel.
BlueSubaru is offline   Reply With Quote
Old 06-16-2008, 06:27 AM   #34
Car: 08 STI
Fav Mod: Removing the window sticker
Exactly - the bendix isn't pushing the drive gear all the way into a mesh with the flywheel teeth, so it just spins and the edges of the two gear grind on each other. Is there an inspection hole in a subaru bell housing? You should see evidence on the flywheel teeth if this is happening; if you can see it show it to the dealer, it should be pretty cut and dry evidence of what is happening.
tshrey is offline   Reply With Quote
Old 08-19-2008, 05:44 AM   #35
Car: UGM 07 STI
Fav Mod: Driver
I know this is an 08 thread but my 07's done this about three times now. Is it something I need to be concerned about? Have you guys had to replaced anything yet?
atanarus is offline   Reply With Quote
Old 08-19-2008, 09:24 AM   #36
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
My '08 no longer does this. The week I requested that my dealership order a new starter, the issue went away. It's been a couple months now and it hasn't happened again. Weird.
Old 08-22-2008, 03:10 PM   #37
Car: white 08 STi
my car just did this for the third time since i got the car in june... guess there's still no real solution yet?? and since it's not a consistent thing i sorta doubt bringing it in will result in anything..
nitram is offline   Reply With Quote
Old 08-26-2008, 07:50 PM   #38
Car: 08 STI
My Cars Been Doing It For Ages,
Sounds Like **** And Sorta Embarrising!
May Have To Try Get A Freebie As Well!
B3ANO is offline   Reply With Quote
Old 08-30-2008, 11:26 PM   #39
Car: 05 wrx--->07 STi
Fav Mod: teH bewstorz
Send a message via AIM to wacerx
my car does this about once a month. it is not consistent with weather conditions, sit time, or anything really. have probably had it happen about 20 times in the last 2 years. every time it happens i cringe but the car always starts on the second try. i really wish this problem would be addressed from subaru if the 08's are also having this problem.
wacerx is offline   Reply With Quote
Old 09-19-2008, 06:47 PM   #40
Fav Mod: Hatchback!
I just joined the club today, ran into safeway for a few things, car sat maybe 5min. On turning the key I got the gawd-awful screeching/grinding. Turned a few heads in the carpark thats for sure. turned the key off and back on again, started without issue.
Hope i'm not going to see this again, i'm sure others were thinking i was a right tool, to get a noise that bad from a new car. I'm innocent
S'poreSTI is offline   Reply With Quote
