Old 04-15-2008, 04:15 AM   #1
Default Anyone install the Homelink/Auto dimming mirror on the 08?
Like the title says, has anyone installed one yet?
I've been itching to get my garage door opener out of the cup holder and onto my mirror, but dont know exactly what is involved.
I'm aware that some of the older models had a pre-wired harness already under the headliner, but I haven't dug around yet for that. Also, if you have done it, what did you do with the glued on tab for the original mirror?
Thanks,
Chris
Old 04-15-2008, 04:40 AM   #2
Car: AW 2006 STi
Default Re: Anyone install the Homelink/Auto dimming mirror?
Just finished installing one. Fairly simple. You need to buy the adaptor from Subaru, for the new mirror, which lets you leave the original piece glued to the windshield. About $12 from subarugenuineparts.com. I bought the mirror off Ebay and it didn't come with the short wiring harness needed to plug into the cars wiring harness above the reading lamps. There's a pigtail pre wired up there. I ordered it from my local Subaru dealer for about $8. If you have to do that, order the wiring harness cover trim piece at the same time because it's different than the original unless you don't care about the exposed wire. I have an 06 STi so I can't speak for earlier years so I would check to see if the pigtail is there. Or, if you already have an auto dimming mirror it's definately there. It's a different wiring harness though. Hope this helps.
Kendallra is offline   Reply With Quote
Old 04-15-2008, 05:38 AM   #3
Ahh, on the 06. Im looking into right now and will still be looking around for more info on the 08. Thank you though.
Has anyone done it on the 08?
Old 04-15-2008, 06:44 AM   #4
Fav Mod: Bride Brix II
Default Re: Anyone install the Homelink/Auto dimming mirror on the 08?
I had the Homelink on my 06 and loved it, so when I bought my 08 with just compass/dim I had to swap it out. I bought the homelink mirror from SubaruGenuineParts.com and it came with all necessary hardware and instructions on how to swap it over. It's really simple, plug and play.
Here's the link I bought: https://www.subarugenuineparts.com/p...oducts_id=1274
Marcus is offline   Reply With Quote
Old 04-15-2008, 07:02 AM   #5
Rum
Car: DGM 08 STI
Fav Mod: Proudly mod-free since 2008
Installation guide for 08:
http://techinfo.subaru.com/html/down...?doc_id=219710
Rum is offline   Reply With Quote
Old 04-15-2008, 07:28 AM   #6
Thank you much. Just what I was looking for.
Old 04-15-2008, 03:22 PM   #7
Fav Mod: Britax Roundabout
You know, I HATE having to look at the garage door remote so I hid it! I just clipped mine right below the steering wheel where the lower dash ends...so it's being held up right between my knees. You don't get the fancy auto dimming mirror but I saved some $$ and don't have to look at my remote.
Old 04-15-2008, 04:02 PM   #8
Yeah as the rest said. I transfered mine from my 07. Just take off the light and there is a harness up there you just clip it in and done with wiring. You just need to make sure you buy the full assembly because you need the piece that hides the wire and the piece that mounts the mirror.
Kilya is offline   Reply With Quote
Old 04-19-2008, 05:55 AM   #9
Car: White/Gold '08 STi
Fav Mod: Right foot
If you are handy, you can wire a remote switch and put the garage door opener in your dash somewhere. The switch you can mount on your dash somewhere.
Old 04-19-2008, 05:57 AM   #10
Haha, I consider myself handy with everything, ....except wiring.
Old 04-21-2008, 11:42 AM   #11
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
I miss it in my old STI.
