IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi GR Series Discussion (2008+) > Technical
Old 04-14-2008, 07:22 PM   #1
Car: Black 08 WRX STI
Default Cobb DP questions
Does it change the sound of the car if I installed the cobb DP... and if it does does anyone have clips so i can compare
NYSTI08 is offline   Reply With Quote
Old 04-14-2008, 07:24 PM   #2
Trader Rating: (15)
Default Re: Cobb DP questions
If you change any part of the exhaust, the sound note will change. If you change just the dp then it wont be very noticeable. There are alot of sound clips floating around in the 08 section. Search is you're friend. Good luck!
Old 04-15-2008, 12:19 AM   #3
Car: WRB 06 WRX STI
Fav Mod: Protune
Should be a lot deeper, especially at WOT... I changed my cat-back at the same time, so couldn't say how much different.
SonicBoom is offline   Reply With Quote
Old 04-16-2008, 02:32 PM   #4
Fav Mod: Britax Roundabout
The change would be imperceptible on a sound clip, it's that subtle. BUT there is a slight increase in volume and you hear the turbo a lot clearer as well.
I think the only way would be to have the exact same recording equipment and environment record with a stock DP and then with a Cobb DP. Maybe then you would be able to tell.
Old 04-17-2008, 04:37 PM   #5
Installed the AP and downpipe and the noise change is minor.
Constant Speed is offline   Reply With Quote
Old 04-17-2008, 05:08 PM   #6
Fav Mod: The Newest One!
It does change it slightly. This is a WRX, but still sounds the same.
YouTube - WRX Exhaust
