Old 04-15-2008, 04:52 AM   #16
Car: 05 WRB STi
Fav Mod: PWT Points
Default Re: My performance alignment results...
Originally Posted by djrossco View Post
Quick question for all who have maxed out the negative camber:
I realize that Toe is going to give you problems with tire wear, but how does your wear look with max negative camber settings? I requested the last time I had an alignment done on my 05 sti that they max neg camber out,evenly and zero the toe... the shop refused stating that it was going to wear the inner shoulders of the tires out too quickly. Having never experimented with alignment settings, I let them set it to factory specs. Anyone w a custom alignment having issues with their tires wearing unevenly?
Simply, how do YOUR tires wear with max negative camber?
Most places will make you sign a waiver stating they are not responsible for excessive wear due to customer specified settings. That being said, take it to another shop in your area that is reputable.
On a stock set up, the max negative camber will barely affect your tire wear on the inner edge, especially if you drive hard and tend to corner hard. This is because you can only typically get around -1.0 degree of neg camber on a stock set up.
Above -1.5 and you are starting to ask for some noticeable wear which dramatically increase from there as you add more and more negative camber.
There's a reason I went with my settings. -1.7 front because I will corner hard with the fronts and -1.5 in the rear. By the time I do rotations and all, they should wear pretty minimally. Plus the little extra negative camber up front really helps the car rotate the way I want.
Old 04-15-2008, 04:55 AM   #17
STI Guru
Fav Mod: grip.
those are some pretty big differences side to side.
Old 04-15-2008, 04:58 AM   #18
Fav Mod: Autotrader.com
I didn't have any issues running 3.5 degrees up front with zero toe on my WRX. Maxing out the stock parts on an STI barely gets you -1.5 degrees, that's not going to cause any problems.
Old 04-15-2008, 06:44 AM   #19
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
On my '05 I ran -2.0 (Whiteline camber bolts) and 0 toe with no ill-effects. I think I had those settings for about a year. None of the shops that I've gotten an alignment from have asked me to sign anything. They look at me funny sometimes but that's about it. Toe is what primarily kills tires.
Do you mean in the stock alignment? Then yes, it was pretty out of whack. The after alignment numbers are as equal as they are going to be; the rear is unadjustable (my '05 had mismatched rear camber as well.)
Old 04-15-2008, 06:48 AM   #20
STI Guru
Fav Mod: grip.
i consider .3 degrees to be a good amount... as long as it feels and drives well you should be good tho.
my 05 has -2.0 on all 4 corners ftw.
im led to believe that is the ohlins struts slotting tho.
Old 04-15-2008, 06:51 AM   #21
I wonder what it would be with you in the car.
Old 04-15-2008, 07:13 AM   #22
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Well the fronts are perfect but the rear is something I can't change without camber bolts. I've never seen someone go with the same camber in the rear as the front, if they can help it. Usually you put more in the front and dial back the rears a touch.
Ohlins struts were to be my next mod on my '05, but I sold it before I bought them (thankfully ).
Once I go back for my track alignment (with all my suspension goodies), I'll be getting the alignment with me sitting in the car (~170lbs).
Old 05-16-2008, 02:41 PM   #23
Car: 08 OBP STi
Fav Mod: Boobies........oh, for a car Boost
glad i found this, why didnt your tech use an 05-08 legacy as his platform on the alignment machine. it seems like the calabration would have been closer due to the similar chasis.
Wales Garage is offline   Reply With Quote
Old 05-16-2008, 04:22 PM   #24
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
He didn't have the calibrations in his database, which needed to be updated. Those are just reference specs anyhow and don't affect the actual alignment.
Old 05-16-2008, 07:00 PM   #25
Fav Mod: Nintendo Decal
Interesting thread... I'm still a little confused on what's the best "stock" settings... My alignment over the last two years is pretty awful now, and the wear on my tires is mostly on the outer edges. I'm replacing them all this summer, so when I get new tires, I'll go for a full alignment with settings.
unrequited is offline   Reply With Quote
Old 05-30-2008, 01:38 PM   #26
Fav Mod: Advan RS 18x9. TurboXS downpipe.
Anyone aware of any rear bolts for 08s?
paikman is offline   Reply With Quote
Old 06-01-2008, 05:40 PM   #27
Car: 08 Subaru WRX STI
Send a message via AIM to RAE129
My steering wheel is off center. I brought the car into the dealer and told them it was off center and tracking to the right. It was realigned but now tracks to the left and the wheel is still off center. Any advice?
RAE129 is offline   Reply With Quote
