Old 04-05-2008, 01:34 PM   #1
Car: Silver 08 WRX STi
Default Noises
hello, very new b
Throwing out the quick questions..
My new 08 STi picked up last Sat did pull to the right with the test drive..per admin Kevin's as far as pre purchase post checking the pressure in the tires revealed 38 lbs in left front 33 lbs others.. adjusted and pull subsided
Steering wheel does seam to be off though
One weeks driving has had my ear working overtime..
1st- noise is after starting and shifting into gear a slight thump, click from under hood ??? maybe the ABS? recall this from of the vehicles
2nd- in the lower gears 3,2,1 decelerating whine(grinding)sound from lower right front
I might be a bit anal, but I see the site will keep me grounded
Break in time is hard to take
kjamsSTI is offline   Reply With Quote
Old 04-06-2008, 06:48 AM   #2
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default Re: Noises
THose sounds are normal. This is a performance oriented car and is noisey even with all of the extra sound deadening they have added.
Old 04-07-2008, 09:53 AM   #3
Car: OBP, 2008
Send a message via AIM to method
Default Re: Noises
^^ which is very little.
My new 08 is quite noisy as well. But I came from another Subaru that was worse so I'm used to it. They are not refined cars at all. You'll learn to like it.
method is offline   Reply With Quote
Old 04-08-2008, 11:46 PM   #4
Default Re: Noises
Thanks for the quick Replies, I figured they were normal... In the rain tonight though the driver side wiper blade stopped working.. yeah... have it removed now and possibly stripped...hope this is not beginning of many things with only 700 miles... maybe I'll just call and have them tow it in (on there dime) Just discouraged.....
K
Old 04-09-2008, 11:25 AM   #5
Rum
Car: DGM 08 STI
Fav Mod: Proudly mod-free since 2008
Default Re: Noises
Would you believe my rear wiper was on upside-down? The first time I used it, it swept down over the hatch instead of up onto the glass. I thought for sure it had scratched the paint, but fortunately not. The dealer flipped it right side up and that was that.
Rum is offline   Reply With Quote
Old 04-09-2008, 07:51 PM   #6
Default Re: Noises
Well,
I tightened the one nut(14mm) holding the wiper arm and it appears to be fixed for the moment. THe black paint is scratched on both arms, top on one bottom on the other. Rust?? I think I'll put in for warranty replacement of them.
You might think the bolt would be of the locking type. Motor post has vertical grooves all the way around the shaft. These a very small or shallow ones. The arm has nothing but a smooth bored hole.. More research.
Thanks for reply
K
Old 04-10-2008, 05:25 AM   #7
Car: 08 STI
Fav Mod: Removing the window sticker
Default Re: Noises
The redesign of the cars made some very nice improvements in this department. A roll of Raamat added to these cars is now a tremendous improvement. Simply coating the outer door skins with the mat drops interior noise A LOT and when you open and close the door (or even release the outer door handle) it sounds like a mercedes.
tshrey is offline   Reply With Quote
Old 04-10-2008, 05:38 AM   #8
Car: STIzzle
Fav Mod: Tint
Default Re: Noises
solovus is online now   Reply With Quote
