Old 04-05-2008, 10:47 AM   #1
Car: silver 08 WRX STi
Default oil change
My first oil change-I drained oil and installed new filter- I followed the owners manual and put in 4.2 qts oil (4qts, 7oz). After I started engine, checked oil level and it looks low. Dipstick is a little hard to read also. Does anyone have any input on if I used the correct amount of oil?
jon08sti is offline   Reply With Quote
Old 04-05-2008, 05:43 PM   #2
Car: WRB 06 WRX STI
Fav Mod: Protune
Default Re: oil change
To get it to read full, I allways end up using almost 5 full quarts (prolly 4.75)...
SonicBoom is offline   Reply With Quote
Old 04-05-2008, 05:46 PM   #3
Car: 06 Subaru imprezaSTi
Fav Mod: Prodrive
i think the 4.2 liters doesn't include the filter
steelgraySTi06 is offline   Reply With Quote
Old 04-05-2008, 07:49 PM   #4
Car: << 07-STi >>
Fav Mod: A Good Wax Job
It does that sometimes...drive it around for awhile and let it settle.....after i do this I still check 3-4 times( wipe the stick good) till I get a good~normal read.....Subies are special...
STIVendetta is offline   Reply With Quote
Old 04-09-2008, 12:12 PM   #5
Fav Mod: Vtec injectors
Let it sit over night and check it in the AM, works for me
ScoobyJDM21 is offline   Reply With Quote
Old 04-09-2008, 12:16 PM   #6
Car: Blue 06 Sti
Send a message via AIM to santacruz02
Read the owners manual again like steelgray06 said, I'm sure it doesn't include the filter. In mine I don't waste my time measuring 4.75 or so, I put the hole thing in there.
santacruz02 is offline   Reply With Quote
Old 04-09-2008, 01:55 PM   #7
Car: 04 WRX STi
Fav Mod: 44mm EWG
I vaguely remember.. But, I remember a few years ago on this forum that the 4.2 Quarts was a misprint within the owners manual.
PhantomSTi is offline   Reply With Quote
Old 04-09-2008, 03:02 PM   #8
I have found that 4.5 quarts seems to bring it to the FULL mark on the dip stick, the owners manual and my Subaru dealer service dept. say it is 4.2 quarts with a filter change. I cannot understand how there can be so much confusion.
Old 04-09-2008, 03:52 PM   #9
Car: 07 OBP STi
Fav Mod: All
The first time I changed mine, I used 4.5 qts and put about 1/3 in the filter itself and it seemed overfull, but hard to tell since I was using Mobil 1. The next time I changed I used conventional and used 4.2 qts and filled the filter up and it reads right at the full circle. Conventional oil coats the dipstick better than synthetics from what Ive noticed.
subydude1974 is offline   Reply With Quote
Old 04-09-2008, 03:55 PM   #10
Car: 05' AW WRX STi
Fav Mod: Passport 8500 X50
i know for the 04-07 the 4.2 quarts is a typo in the manual and its really 4.8. possibly same in 08?
Old 04-09-2008, 04:46 PM   #11
Car: 08 sti
According to the service manual, for 2008 STi oil capacity:
When replacing engine oil and oil filter:
Litres - US qt - Imp qt
4.3 - 4.5 - 3.8
When replacing engine oil only:
4.0 - 4.2 - 3.5
Oh, and torque on the oil drain plug is 32.5 ft-lbs. (remember to use a new gasket).
008STI is offline   Reply With Quote
Old 04-09-2008, 05:42 PM   #12
Car: 05' AW WRX STi
and a crush washer on the oil drain plug
Old 07-12-2008, 07:09 AM   #13
Car: 05 AW Subaru WRX STi
what side of the crush washer goes where? like one side of the crush washer is tapered and the other side is flat...im guessing the tapered side goes to the oil pan and the flat side goes towards the bolt?
b00st3d is offline   Reply With Quote
Old 07-12-2008, 07:56 AM   #14
Car: 05' AW WRX STi
yea..
Old 07-12-2008, 01:10 PM   #15
Car: 09 L.L.Bean Forester
Fav Mod: Not having one
how many mile do you have on it already?
Nativepenguin is offline   Reply With Quote
