Old 04-06-2008, 08:35 AM   #16
_
Fav Mod: 2008 STi
Send a message via AIM to Spaceman Send a message via Skype™ to Spaceman
Default Re: VDC, DCCD, and SI-DRIVE Explained! (Great Info)
Originally Posted by BlueF View Post
From last month's DRIVE mag. : )
A lot of the new STi owners won't see that magazine.
Spaceman is offline   Reply With Quote
Old 04-10-2008, 01:05 PM   #17
so, is this correct on the 2008s ?
DCCD in Manual mode
with no bars, it's a 35F/65R torque split ?
Making the car the most rear biased possible ?
kujo is offline   Reply With Quote
Old 04-11-2008, 08:14 PM   #18
Car: drkgrymtalc 08WRXSTI
Actually,
I think the max rear torque bias can be is 59% in the '08s.
speeddoc74 is offline   Reply With Quote
Old 04-17-2008, 02:20 PM   #19
Car: Silver 08 WRX STi
Fav Mod: Mud Flaps/AP Stage 1
Idea's anybody...What would be the most economical settings for the VDC & DCCD combo. I do 95 miles a day to and from work...I flash the economy map for the work week,then reflash stage1 for the week end.
Thanks
Giant is offline   Reply With Quote
Old 05-03-2008, 06:44 AM   #20
Car: Black 08 STi
Fav Mod: Cobb access port
Send a message via AIM to Photothug
VCCD on Auto and I Drive is my guess. Haven't owned the car long enough to give personal advice though. Man...this car is smarter than I thought. That drive article was good though. For once they have a good article in there, instead of the normal, "great picnics to take with your dog in your Baja".
thanks for the links and stuff.
Photothug is offline   Reply With Quote
Old 05-03-2008, 02:34 PM   #21
Car: 08 OBP STi
Fav Mod: Boobies........oh, for a car Boost
why isnt this a sticky?
Wales Garage is offline   Reply With Quote
Old 05-03-2008, 02:53 PM   #22
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
I didn't even notice this thread before but it should definitely be a sticky, so I'm going to make it stick.
Old 05-03-2008, 02:56 PM   #23
Fav Mod: student
Send a message via AIM to fry_ed
well, the article's explanation of DCCD is pretty horrible....
The DCCD in [-], or with the minimum # of bars allowed, fixes the torque split at 41/59, essentially, while allowing the front to rotate at a speed which is independent of the rotational speed of the rears. Like the article says, this is good for spirited driving on high traction surfaces, good for tight turns (like, oh, doughnuts for example ). Bad for driving out of a ditch.
The DCCD in [+], or in LOCK, essentially fixes the fronts and rears such that they must rotate at the same speed, essentially, allowing the torque split to be as much as 100/0 if the fronts are on tarmac and the rears are on ice, for example. Like the article says, this is good for slippery surfaces. Bad for canyon carving.
If left in AUTO, under normal driving conditions, the car will just default to OPEN ( [-] or minimum # of bars) if you're turning, and LOCK if you're driving in a straight line. Manually putting it in OPEN is going to be better for mpg, as well as benefiting drivetrain longevity.
What is best for racing is debatable.
OK, now someone else elaborate on the SI-Drive and VDC portions of the article...ha...
fry_ed is offline   Reply With Quote
Old 05-03-2008, 03:33 PM   #24
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
It seems the DCCD info is actually referring to the '05 setup.
Old 05-04-2008, 07:03 PM   #25
Car: DGM 08 WRX STI w/Nav
Fav Mod: Howard Stern on Sirius Satellite Radio!
Send a message via Yahoo to The Sim
*edit: already discussed*
The Sim is offline   Reply With Quote
Old 05-04-2008, 07:04 PM   #26
The first article he posted above is for the 2008 STI. The other was from the earlier system, and the SI-Drive info was for the 2007 Legacy / Outback... but the general principles are all the same.
Old 05-13-2008, 07:07 PM   #27
Quick question about the SI drive while driving...
This may sound VERY newbie, but am I supposed to be able to change the SI drive mode (S to S#, I to S#, etc) during actual driving? I thought it was supposed to be locked out while the car was in gear/moving, and only adjustable when in neutral or stopped.
Old 05-13-2008, 07:10 PM   #28
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Yes, that is the point of SI drive.
Old 05-13-2008, 07:12 PM   #29
Car: White/Gold '08 STi
Fav Mod: Right foot
Its totally fine to change it during driving.
Old 05-13-2008, 07:13 PM   #30
OK. Thank you.
