Old 04-03-2008, 03:33 PM   #1
Default Gas Lever
So I just got my STi brand new 08, and I cant seem to figure out the gas door and lever. I pull it up and let it go and still doesn't open. Only time it works is when I pump it then go to it and push the top left so it opens. Anyone else with an 08 STi tell me if this is normal or if I am doing something wrong?
Thanathos is offline   Reply With Quote
Old 04-03-2008, 03:35 PM   #2
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Default Re: Gas Lever
Hmmm, that's definitely not normal. Mine pops open just enough to put a finger in to open it. It sounds like your filler door latch might need adjustment.
Old 04-03-2008, 06:36 PM   #3
Car: 08 STI, 05 Legacy
Fav Mod: dirt, grime and brake dust
I have the same issue. There is a metal clip near the hinge that needs to be adjusted. I would bring it back to the dealer and have them fix it. This will also help alert SOA that there is an issue. This doesn't seem to be an STI specif issue. There are a few people over at 3gwrx.com that have the same problem
Edvig is offline   Reply With Quote
Old 04-03-2008, 07:47 PM   #4
Car: White/Gold '08 STi
Fav Mod: Right foot
Maybe bend the metal out a little so it pops out harder?
Old 04-04-2008, 03:34 AM   #5
Yes...that's basically the fix, but the OP should go to the dealer. This way a report is filed with SOA. This way they can track the problems with our cars.
Old 04-06-2008, 10:05 AM   #6
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
Mine was stuck the other day. I diddnt think I was going to be able to get gass.
Old 04-06-2008, 10:17 AM   #7
I have had the same issue, but eventually it would open. I will mention it to the dealer next trip per Edvig's good suggestion.
GeorgeWrx is offline   Reply With Quote
Old 04-06-2008, 10:26 AM   #8
JWA
I had the same issue as well. I had to pull the lever a few times and it would usually only open just a bit, then I'd have to be careful to get my fingers on the edge just right without it popping back shut.
JWA is offline   Reply With Quote
Old 04-06-2008, 02:05 PM   #9
This is exactly what happens when I try to open my gas tank too.
Old 04-07-2008, 07:24 AM   #10
same here. it opens a crack and i have to use the credit card to open the door and pay for the gas! bending the clip is tricky-too much and it falls off.finally i got it right.
bwana is offline   Reply With Quote
