| Authorized Vendor | Back in the day the Whiteline WRX bar could fit the STi. Not super awesomely good, but pretty darn well, and be functional. Wondering if that was the case this time around we, and Tom@Kartboy started to do some experimenting. We can say for a fact that the 2008 WRX bar WILL NOT fit the 2008 STi. It's too short by quite a bit on each side. When I say quite a bit we're talking more than just a few mm, we're talking 10's of mm. My theory is this - Subaru wanted to keep the same wheel rate for both cars. Since the STi has a so much wider track they had to move the mounting tabs for the bar outward to compensate. (we know the strut/spring motion ratio on the front of each is pretty much the same so no problem there) Given this I REALLY need to take measurements of the WRX rear end mounting points and see if they did the same thing there. If they did then they kept they shot for the same motion ratios for both cars despite the track width differences. AND if that's the case I can use the same valving for coilovers on both setups instead of two different setups. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Authorized Vendor Fav Mod: Most Copied parts on IWSTI! Location: San Diego, CA Posts: 329
IWSTI Addict since: May 2004 Trader Rating: (4) | but do you really think SOA is that smart? ![]() i'll get you some more measurements when i get back to the shop monday. T |
| | #4 |
| Junior STI Driver Car: 08 OBP STi Fav Mod: Boobies........oh, for a car Boost Location: Hunting DrewBears<3 Posts: 185
IWSTI Addict since: Nov 2007 Trader Rating: (0) | from what ive been told and the part numbers ive seen the BL legacy gt front bar will work. check perrin, cobb, and cusco websites |
| | #8 |
| Professional STI Racer
Car: 02 Penis Extender Fav Mod: Autotrader.com Location: Philly Posts: 822
IWSTI Addict since: Jan 2006 Trader Rating: (1) | Does anyone know if the Perrin 08WRX bar works on an 08STI? Their part numbers are the same but I have my doubts. edit: Annnnd the answer is no. Perrin's site is wrong. The STI part is due out in 3-4 weeks. Last edited by waktasz; 04-01-2008 at 07:04 AM. |
| | #10 |
| Amateur STI Driver | The 2008 Sti front stabilizer bar is 20mm; the rear bar is 18mm, as measured by digital caliper on the bar. This ad is not endorsed by this member. Please register or login to hide this ad. |
