Old 03-27-2008, 02:44 PM   #16
Fav Mod: Britax Roundabout
Default Re: Smoke?
It is in Stage 1/2 map notes. See below...
Old 03-27-2008, 08:05 PM   #17
Car: 08 dark grey sti
Default Re: Smoke?
Originally Posted by silvrbulit04 View Post
Hey all, I have a 08 STI. Just had the exhaust done. Flashed stage 2 with the access port. I had gone to the corner store and when i started my car to leave alot of white smoke was flowing out of my exhaust for a min or so. It was pretty heavy. Where the hell could this have come from any ideas? Thanks
My car puffs white/blue smoke, something like your car when i start it up. it needs to be parked abit of it won't do it.
MJKustom is offline   Reply With Quote
Old 03-27-2008, 08:13 PM   #18
Fav Mod: wingless and mis-fires
Send a message via Yahoo to toogood
Default Re: Smoke?
do you have an A/F gauge? if yes, what are your numbers?
you should have a friend drive behind you when you drive and tell you what color is showing when you drive and also if the smoke is just constant or only when you shift
white smoke= lean
blue= rich
toogood is offline   Reply With Quote
Old 03-27-2008, 08:20 PM   #19
Car: 07 Subaru WRX STi
Default Re: Smoke?
You can check which base map (as well as real time map) that is flashed by plugging your AP into your computer.
My 07 has smoked twice since I bought it last summer. It freaked me out the first time as well until I looked into my exhaust and saw water coming out (Condensation).
What is the difference between cobb's stage 2 real time and reflash. When i flashed to stage 2 i used the real time map. Could this be my problem
wchow16 is offline   Reply With Quote
Old 03-27-2008, 08:20 PM   #20
Car: White 08 STI
Default Re: Smoke?
woa... umm
a white cloud is often a sign of a blown headgasket, due to buring coolent. generally check the dipstick to see white goo... and check the oil cap for white goo.
blue is often oil. so it could be either the valve seals, rings or headgasket. compression test will solve this.
now if its just a "white" cloud, which consists of only water vapor, then we can talk tuning issues.
talsnic is offline   Reply With Quote
Old 03-27-2008, 09:00 PM   #21
HowTo Contributor
Fav Mod: Stg 2 - STRI gauges
Default Re: Smoke?
lol tals.... your an optimist i can see.... its an 08 lol, like everyone else is saying its probably just something in the exhaust or something to do w/ how he flashed the car..... my 03 wrx was a smoke cloud but i was catless runnin stg 2 OTS..... and it only smoked here and there..... i highly doubt anything in the engine has failed already unless he didnt break it in properly
Old 03-28-2008, 02:11 AM   #22
Default Re: Smoke?
silvrbulit04 is offline   Reply With Quote
Old 03-28-2008, 04:17 AM   #23
Car: Silver 06 WRX STi
Fav Mod: 3" G-Reddy cat back xhaust
Default Re: Smoke?
Dont' stress about it, I had the same problem. Discovered that engine oil level was too high. I Drained oil to correct level... never had the same problem again.
MadVally is offline   Reply With Quote
Old 03-28-2008, 04:28 AM   #24
Default Re: Smoke?
I was wondering that my oil looks a little high. there is only 500 miles on the car and the smoke out the tail pipe looks blue like its burnning oil. only on start up after it sits a couple of hours. Thanks i will try that
Old 03-28-2008, 01:29 PM   #25
Default Re: Smoke?
Old 03-30-2008, 08:41 AM   #26
Default Re: Smoke?
Old 03-30-2008, 08:47 AM   #27
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
Default Re: Smoke?
new exhausts do burn sometimes.
Old 03-30-2008, 04:08 PM   #28
Car: White/Gold '08 STi
Fav Mod: Right foot
Default Re: Smoke?
Do not realtime flash ever, even if changing from one cobb map to the other. I noticed really inconsistent results using realtime. Just reflash it.
