Old 03-20-2008, 04:18 AM   #1
Car: DGM 08 STI
Default K&N filter?
hey guys I tried looking for a K&N drop in filter and this company tried to charge me 95bucks!! and it wasn't even in stock.. can I use a LegacyGT one? Thanks a lot!
-Young-
TarmacST1 is offline   Reply With Quote
Old 03-20-2008, 06:16 AM   #2
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default Re: K&N filter?
I wouldn't. There have been some logs showing very negative affects of even changing a filter.
Old 03-20-2008, 08:46 AM   #3
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
Yes the LGT filters will fit, but as stated its not recommended.
RallySportDirect is offline   Reply With Quote
Old 03-20-2008, 04:44 PM   #4
Car: 08 Silver STI
What are the negative effects of adding a drop in filter? Does this pertain to all intake kits for 08' STI or just drop in filters?
323sleeper is offline   Reply With Quote
Old 03-20-2008, 05:04 PM   #5
Car: 06 STI
Fav Mod: Stage 2 for now :)
Send a message via AIM to Chinky_Sti
so are you guys saying its bad to put a k&n drop in filter in any sti
Chinky_Sti is offline   Reply With Quote
Old 03-20-2008, 06:43 PM   #6
Car: DGM 08 STI
wow even a drop in have problems? runs lean?
Old 03-20-2008, 07:10 PM   #7
Trader Rating: (53)
It negatively affects the accuracy of the MAF readings. There has been some posts with logs about it.
Old 03-21-2008, 02:46 AM   #8
Car: DGM 08 STI
hmmm i guess I should forget about that then... anything you guys recommend?
Old 03-21-2008, 08:55 AM   #9
Car: 08 Silver STI
From what I thought is that the MAF measures air temp and air volume going into the motor. With the panel filter being in front of the MAF then the computer/ECU should be able to learn the increased air flow and temp if any and make adjustments as necessary. The percentage of incresed air flow from a drop in filter i think is within the small percentage that the factory ECU can correct with out a problem if need be. I can understand if you use a CAI or something that will drastically increase air flow then maybe the MAF calibration and ECU may not be able to correct itself. correct me if I'm wrong.
Old 03-21-2008, 09:02 AM   #10
the stig's skinny cousin
Car: 06 WRX STi
Fav Mod: my furry little four legged Australian Sheppard co-pilot
Send a message via AIM to atsi sti
I got a drop in filter just so the turbo can grab the air easier, should I switch back to my stock air filter?
atsi sti is offline   Reply With Quote
Old 03-21-2008, 08:28 PM   #11
Car: 08 Silver STI
How does the car run with the drop in filter?
Old 03-21-2008, 09:38 PM   #12
Car: 06 WRX STi
Honestly I really havent noticed a differance, but i baby the car. If anything the turbo spools sooner, and it makes life easier on the turbo.
Old 03-23-2008, 09:54 PM   #13
Car: 08 Silver STI
No idle issues?
Old 03-24-2008, 03:55 AM   #14
Car: 06 WRX STi
Originally Posted by 323sleeper View Post
No idle issues?
No none, it runs perfectly fine. Im running cobb stage 2. Im not too sure if they have it tuned where you can run a drop in too
Old 03-24-2008, 03:26 PM   #15
Car: DGM 08 STI
I just got it and put it in today. it idled a little funny for a bit, but it went to normal. after i shut it off and tried to start it later it didn't want to start... but now it's all good. it runs a little better because boost comes about 500rpm sooner.
