| | #16 | |
| Super Moderator Car: 08 DGM STI Fav Mod: My wife :) Location: Brooklin, Ontario Posts: 5,625
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Quote:
I found I went through water in my '05 way too fast and it didn't do enough to make a difference. Obviously, the water will remove some heat from the IC but is it enough on a hot day, in traffic, when there is very little air blowing across the IC? I doubt it very much. I'd also question how good the spray pattern is at speed. If I was going to spend money on something that I had to refill, it would be a meth kit + tune. Now that is something that has proven gains. Not my thing, but I'd take it over an IC sprayer. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #18 |
| Senior STI Driver | I was just thinking about this the other day. |
| | #19 |
| STI Driver Car: 08 STI Fav Mod: Driver Location: Durham, NC Posts: 201
IWSTI Addict since: May 2007 Trader Rating: (0) | The 08's engine bay runs far much cooler than the previous years, and yes the side vents do work well. I can always feel the heat coming from the side vents even when the car is at a stand still. The coolant temperature is what sold me as well. On my 07, while driving at cruising pace, the coolant temp would fluctuate between 193 - 196. On the 08, it stays between 183 - 188's range, so it appears that subaru has finally done their homework in keeping the engine bay as cool as possible. |
| | #20 | |
| Junior STI Driver | Quote:
| | #21 |
| Junior STI Driver | btw, I used a cheapo patio misting kit to make a mister out of my windshield washer rear pump. I never used it anyway. I don't know how much performance gains I'm getting if any (don't have an intake temp gauge besides AP one which I'm told is at the MAF before turbo or intercooler) but I mostly did it because it was a fun DIY and not too difficult ![]() Note: I didn't have to do any special wiring to "disable" the wiping function on spray because the rear doesn't activate the wiper unless you hold the spray for a good 2+ seconds. So if you pulse it you can avoid dry wiping if you like. |
| | #24 |
| Junior STI Driver | OH RLY? hmm.. I didn't know that. cool. Also I wanted to add that from a pretty extensive intake temperature research guide I read my conclusion of the only benefit I would gain would be improving the heat sinking abilities of the IC, meaning it should maintain a lower temperature longer before turning into a radiator. Again, dunno if I ever hit that point until I go to the track but it was a fun 1 afternoon DIY anyway This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
