Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Tires & Wheels
Old 03-10-2008, 06:51 PM   #1
Car: dark gray 08 sti
IWSTI Addict since: Mar 2008
Default new rims for 08 sti
does anyone know what is the largest size tires/rims i can put on a 08 sti without any mods to the wheel well to prevent rubbing? thanks
unknown is offline   Reply With Quote
Old 03-11-2008, 06:13 AM   #2
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Default Re: new rims for 08 sti
Looks like 18x9.5 et45 with a 265 35 18 tire is about the max. you could probably going with a 48 offset and fit a 275.
Old 03-11-2008, 08:41 AM   #3
IWSTI Addict since: Oct 2003
Do you know what's the largest width tire that can fit on the stock 18x8.5 et55 rims without rolling fenders?
Emissary is offline   Reply With Quote
Old 03-11-2008, 12:28 PM   #4
Car: 08STI,02WRX-H6Turbo
IWSTI Addict since: Jan 2004
I am running JIC 18x9.5s 45 offset, 275 35R18s, and the fronts clear fine. The rears need a small amount of out fender roll. Not a lot, just a touch near the 9 o-clock position.
I suspect that 265s on the same wheels would clear perfectly.
Jeff
sponaugle is offline   Reply With Quote
Old 03-24-2008, 07:41 PM   #5
Car: 08 Silver STI
Jeff
Do you have any pics of your setup?
323sleeper is offline   Reply With Quote
Old 03-24-2008, 07:53 PM   #6
Car: Titanium Gray 04 RX8
IWSTI Addict since: Jan 2008
Do you know if a 255 width tire, with 9.5in rim 38 offset would fit? If not, what tire (if any) would fit with that rim?
Moostafa29 is offline   Reply With Quote
Old 03-28-2008, 09:17 PM   #7
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
IWSTI Addict since: Sep 2004
The whole idea is to get the most tire under your car. Going the "euro stretch look" is going to get shot down faster than a zero. If a slight roll or different offset rim is going to get you a 275 under your car, than anything else would be a waste of time.
