Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Suspension, Handling, Stiffening
Old 03-09-2008, 03:14 PM   #1
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Default Throw out bearing problems???
I have noticed noise from what I think is my throwout bearing after starting the car when it is bone cold. It sounds like a rotational grinding noise and only happens with the clutch out. When I put the clutch in it goes away. It has been doing this for about two or three weeks. After a minute or so the noise goes away completely. I have about 1600 miles on the car currently. I really don't want to have to swap the damn TO bearing as it's such a PIA.
Anyone else getting any noises like this?
Tony
Old 03-09-2008, 03:38 PM   #2
Car: OBP 08 STI
Fav Mod: AccessPort
IWSTI Addict since: Jan 2008
Default Re: Throw out bearing problems???
yes me to, though I have no idea what it is. To me it sounded like something was vibrating. I can hear it when I start the car up in the morning.
sleepyhead is offline   Reply With Quote
Old 03-09-2008, 03:43 PM   #3
Car: 99 Civic POS
IWSTI Addict since: Nov 2007
throw out bearing will whine when u push the clutch in. if your clutch pedal is misadjusted and its slightly touching the pp, then it could do that, but i would think it wouldnt go away.
nautique196 is offline   Reply With Quote
Old 03-09-2008, 03:55 PM   #4
Trader Rating: (53)
Could the signs be reversed if it is a pull type instead of push? I haven't taken it apart yet so I don't know. Wonder how many other examples of this are out there?
Tony
Old 03-09-2008, 04:33 PM   #5
Car: Silver '08 STi w/BBS
Fav Mod: WC Lathe Werks Copolymer Sphere Shift Knob
Mine does the same thing.. it rattles at idle, goes away when I push in the clutch, and is silent when the car warms up.
Does the STi have a single mass flywheel in there? That could be the reason. Single mass flywheels do transmit noise at idle, though it usually doesn't go away when the car gets warm (AFAIK).
rj45 is offline   Reply With Quote
Old 03-09-2008, 04:42 PM   #6
Car: 2008 SSM Sti
Fav Mod: Just Getting Started.....
ssauer2004 is offline   Reply With Quote
Old 03-09-2008, 05:03 PM   #7
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
IWSTI Addict since: Sep 2004
Mine too
Old 03-09-2008, 05:13 PM   #8
Trader Rating: (53)
Ok, so this is starting to seem "normal". Not that I like that. Anyone reported it to Subaru to see what they say?
Tony
Old 03-09-2008, 05:49 PM   #9
Car: 08 STI, 05 Legacy
Fav Mod: dirt, grime and brake dust
IWSTI Addict since: Feb 2008
I hear the same sound too. It would be good to know what it is.
Edvig is online now   Reply With Quote
Old 03-09-2008, 09:42 PM   #10
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
IWSTI Addict since: Oct 2003
Tony
I had this in my '05 and it annoyed the hell out of me. It only seemed to happen when the car had been sitting for a bit in the cold. When starting up the car it would make a slight squealing noise and even the lightest pressure on the clutch pedal would stop the noise. Subaru replaced the entire clutch under warranty and the issue never came back (iirc).
Tony
I'm pretty sure only the '04-'05 was a pull-type. Starting in '06 I believe Subaru went to a push-type.
Old 03-09-2008, 10:16 PM   #11
Car: Black on Gold 08 STi
Fav Mod: ...
IWSTI Addict since: Dec 2007
Mine doesn't make this noise. If i were you guys i would get it checked out.
Mediumturbo is offline   Reply With Quote
Old 03-10-2008, 09:44 AM   #12
pwn
Car: WRB 08 STI
Fav Mod: Only one - Cobb AP
IWSTI Addict since: Jan 2007
Send a message via AIM to pwn
lol. me thinks that was the "oh ****" moment.
Anyone give SOA a call yet?
pwn is offline   Reply With Quote
Old 03-10-2008, 11:17 AM   #13
IWSTI Addict since: May 2005
Mine has the same noise.
UturnSTi is offline   Reply With Quote
Old 03-10-2008, 11:38 AM   #14
Car: 04 SUBARU WRX sti
Fav Mod: JDM FOGS
IWSTI Addict since: May 2006
When i had about 20k miles on my 04 i had this problem and i took it to the dealer and they replaced the throwout bearing.
Old 03-10-2008, 11:44 AM   #15
IWSTI Club Level 1
Car: The Spaze Mobile
Fav Mod: Tuning
IWSTI Addict since: Jan 2006
Tony
Do you have an aftermarket clutch? This problem has been documented on Nasioc before, I think there is a big thread about it.
There are a lot of things it could be imo. I think it has a lot to do with the way the throwout bearing mounts to the clutch fork. Something is always touching in that area.
Anyways, Both of my friends (Who have aftermarket clutches have this problem). On one of the cars, I really lubed up the clutch fork guide rod and clutch fork to throwout bearing and the car made no rattles for weeks. Then one day it started up.
