Old 03-09-2008, 12:21 PM   #1
Car: White/Gold '08 STi
Fav Mod: Right foot
Default Radar detector install
Does anyone know if the dome light at the front of the car has constant 12V power? I want to hard wire up my radar detector. Also, does that dome just pop off, or would I have to remove the headliner to get to the wiring!
Bonus points awarded for pictures!
Old 03-09-2008, 12:44 PM   #2
Fav Mod: Boost gauge
Default Re: Radar detector install
Search, and you will find a write up with pics. Yes the map light has an ignition on hot wire. It also has a constant on but I don't know why you'd want that.
Old 03-09-2008, 12:46 PM   #3
Fav Mod: Right foot
Sorry, you're right.. I meant ignition.
Old 06-10-2008, 10:57 AM   #4
Fav Mod: Magnaflow exhaust!
I hard wired mine into the fuse panel. the radar sits on dash at the a pilar and wiring goes down into the dash to the fuse panel. there is an open port and the power is constant when key is on. That is how I did mine.
GiantSub is offline   Reply With Quote
Old 06-10-2008, 01:54 PM   #5
Car: 08 Gray STi
Documented this a few weeks back and also addressed it in another thread earlier today.
2008 Subaru WRX STi - V1 Hard Wired Installation
Old 06-11-2008, 12:34 AM   #6
Fav Mod: Custom Sound System
the pics are dead on, but i'd recommend buying and learning to use a test light. It's a simple enough project to learn through and knowing how to use a test light can save you a lot of trouble when you move onto more complex projects. Goodluck!
calves is offline   Reply With Quote
Old 07-02-2008, 07:41 AM   #7
Car: 08 Gray STi
Better than a test light, is a Mutlimeter. Much more useful in a variety of situations. Here's an inexpensive one from Radio Shack.
RadioShack.com - Cables, Parts & Connectors: Test & measuring equipment: Multimeters: 15-Range Digital Multimeter
I also picked up one that packs small enough that I can carry it in my motorcycle tool pouch.
M810B, Super Small size Multimeter
How to use one: YouTube - How To Use A Multimeter
and
Multimeter Tutorial
