| S204 Racer | i'm trying to replace the OEM grille with a new sports grille. the instructions that come with it are not clear. do i need to take the whole bumper off to get the grille out ? J. This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by jph; 03-21-2008 at 11:30 AM. |
| | #2 |
| S204 Racer | damnit! it looks like i have to remove the front bumper in order to remove the grille! and i can't figure it out! ![]() J. Last edited by jph; 03-08-2008 at 03:15 PM. Reason: i can't spell |
| | #3 |
| Junior STI Driver
Car: Alp White 2008 STI Fav Mod: ... Location: San Jose Posts: 60
IWSTI Addict since: Dec 2007 Trader Rating: (0) | Its pretty easy to pull off the bumper. Did you figure it out yet? There are the 4 snap locks along the inside hood then there are six snap lock fastners on the bottom that attach the bumper to the under tray and then there are 3 in front of each wheel and a strange rivet thing. After those are out, I started at the wheel wells and the bymper jsut unsnaps so to speak along that seam. Then it unsnaps from under the headlights and its off. THe fasteners are all those kind that you un screw just a quarter turn and the middle section pops out, then they pull out. I've got pics from mine but don't have them posted yet. Steve |
| | #4 | |
| S204 Racer | Quote:
haha.i'll have some pics up in my journal in a little while. i also removed the silencer while i was inthere. J. Last edited by jph; 03-08-2008 at 03:16 PM. | |
| | #5 |
| Silver Member
Car: '08 DGM STI w/BBS Fav Mod: Britax Roundabout Location: L.A. Posts: 1,176
IWSTI Addict since: Jan 2008 Trader Rating: (0) | No need to remove the bumper. Remove the two set of clips connecting the grille to the body panel immediately in front of the radiator. There are four screws you need to remove from the lower side of the grille. You'll need to snake your arm down from the opening you created from removing the clips. Once you have the four screws out, simply pull the grille out toward the front of the car. You will need a VERY stubby phillips head. |
| | #6 | |
| S204 Racer | Quote:
i have skinny arms, and was not able to do it that way ![]() J. | |
| | #7 |
| Silver Member
IWSTI Addict since: Jan 2008 Trader Rating: (0) | yeah, you do a bit by feel since it's tough to see. I also have this neat philips head that is about 2 inches long which allows me to work in close quarters...picked it up from Sears. I've removed the front grille twice without ever removing the bumper cover, and my arms are by no stretch of the imagination skinny. |
| | #8 |
| Banned
Car: 2008 wrx sti wrb Fav Mod: brown chicken brown cow Posts: 530
IWSTI Addict since: Mar 2008 Trader Rating: (0) | Don't remove the bumper!!! I did mine with a stubby Phillips like GilMikalian describes. |
| | #10 |
| Silver Member
IWSTI Addict since: Jan 2008 Trader Rating: (0) | Looks like I'll be removing the bumper to disconnect the second horn. By the way, are the fog lights any more accessible with the bumper removed? I need to swap out the white bulbs for some yellow ones I got. |
| | #11 |
| Junior STI Driver | You definitely don't have to remove the bumper. Pop out the 4 plastic locks on top. Then instead of trying to squeeze your arm down through the top, just go up from the bottom. Reaching through the lower opening is cake. Just unscrew the 4 screws (you do need a short screwdriver) and pull the grill towards you. There are two long tabs on the back, squeeze them up as you push the grill out from behind. This ad is not endorsed by this member. Please register or login to hide this ad. |
