Old 03-02-2008, 02:21 PM   #1
Default Changing the outside temperature gauge from Fahrenheit to Celsuis?
I just brought an 08 STI to Canada from the U.S.
Can you change the outside temperature gauge from Fahrenheit to degrees Celsuis?
If so, how do you go about doing this? Thanks!
Wronks is offline   Reply With Quote
Old 03-02-2008, 02:36 PM   #2
i eat cones
Fav Mod: 18x8
Trader Rating: (18)
Default Re: Changing the outside temperature gauge from Fahrenheit to Celsuis?
havent heard of doing so.
Old 03-02-2008, 02:40 PM   #3
Car: 05 obp STi
Send a message via AIM to dscoobydoo
You might ask the dealer about that.
I am guessing there is something in the electronics that makes it F, or else the sensor sends the number signal.
dscoobydoo is offline   Reply With Quote
Old 03-03-2008, 06:12 AM   #4
Car: 06 STi cobb stage 2
I know for the 04-07 you can't change it and this was after they installed the new gauge cluster to KM's
frcefed is offline   Reply With Quote
Old 03-26-2008, 12:09 AM   #5
Car: 08 sti
According to the service manual, it cannot be changed electronically, as the clock display units are different between Canada and the US. The US unit actually doesn't even have a "C" (Celcius) marking, and the indicators for the airbags status are different as well.
008STI is offline   Reply With Quote
Old 03-26-2008, 10:05 AM   #6
Thanks for your help. That's what I figured, but I thought that I would ask anyway.
Cheers.
