Old 08-16-2008, 12:09 AM   #91
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
IWSTI Addict since: Oct 2003
Default Re: '08 STi - CODE P0244 - Overboost
Originally Posted by BobaSti View Post
Threw a cell 0244 at about 110mph in 6th gear going uphill with 1 passenger and AC on. My car is a complete stock with ecutek tune.
Sorry, I'm confused. You have an ECUTek tune but are completely stock or did you mean that the only mod you have is an ECUTek tune?
Anyhow, you probably just spiked past the boost limit for your particular tune. Do you know what your tuner set the cut-off to?
Old 08-16-2008, 06:37 PM   #92
Fav Mod: Proper Alignment
IWSTI Addict since: Nov 2003
I threw an overboost code three times today on a rainy track day in Colorado. I switched to "S" mode for the last two seesions just to get through the day and didn't have any further issues (other than crappy throttle response!)....
Looking forward to a fix myself!
UberWagon is offline   Reply With Quote
Old 08-17-2008, 12:02 AM   #93
Car: 08 STi silver
Fav Mod: window tint
IWSTI Addict since: May 2008
only mod i have is ecutek tune, no cai,d/p,cbe.
BobaSti is offline   Reply With Quote
Old 08-19-2008, 10:37 AM   #94
Car: Red 2008 STi
Fav Mod: 1L Rockstar
IWSTI Addict since: Aug 2008
might be in the tune that you have the same issue so i have to call Revolutions in CO about the tune, its will do it when you hit 4th gear, at about 5165 for the RPMs dont ask, it just does.. a buddy thats a subaru guru out here wanted to see when it does it so we hooked up the AP and bame 5165 cut out went into limp mode. but yeah its the tune get it looked at again.
Red08onGOLD is offline   Reply With Quote
Old 08-19-2008, 12:45 PM   #95
Car: DGM 2008 STI
Fav Mod: Cobb DP & ProTune
IWSTI Addict since: Jun 2008
Big thumbs up for Revolutions. Adam and the boys did a great job on my car!
08DenverSTI is online now   Reply With Quote
Old 08-22-2008, 06:40 PM   #96
Fav Mod: Cobb AP
IWSTI Addict since: Jul 2008
just happened to me today, high into 4th gear and shifted into 5th so i must have been at around 5500 rpm and bam fuel cut and CEL p0244....was a bit on the chilly side this morning also, around 60 degrees.
butcherboy78 is online now   Reply With Quote
Old 08-23-2008, 12:03 PM   #97
Friendly Lurker
Car: 08 STI
Fav Mod: RCE Camber Plates
IWSTI Addict since: Mar 2008
Are people getting overboost (P0244) on the Perrin map or just the Cobb?
Old 08-23-2008, 02:23 PM   #98
Fav Mod: Cobb AP
mine was with the Cobb S1 93 octane map...i switched to a Clark Turner map that i bought last night and absolutely love it....he made it for a daily driver with power all throughout the RPMs and it pulls all the way up to 6000+ (i shift at 6k)
Old 09-21-2008, 06:31 PM   #99
Car: 08 WRX STI WRB
Fav Mod: Harman Motive TBE
IWSTI Addict since: Aug 2006
Just got the PO244 for the first time today. I am running a Cobb Stage 2 map v1.01 with the latest firmware updates. I also have a Harman Motive full turboback exhaust. Should I get the Perrin tune? Happened as I was accelerating through 5th gear accelerating onto the highway.
wrxlep is offline   Reply With Quote
Old 11-20-2008, 09:23 PM   #100
Car: 02 Stg2+ WRX, 08 STi
Fav Mod: pink I badge
IWSTI Addict since: Apr 2008
just some more data:
I have had two overboost CELs in the last two days. They both occured under WOT while passing something slow in front of me. I was at about 5-6k rpm and 18+ boost. I was at about 7500ft elevation and it was maybe 40 deg F ambient. I had been driving hard up a canyon. I live in Boulder CO.
This is the first issue I have had with a Perrin map. The map is a OTS 93 oct 'high elevation' map Jeff made for me when I purchased the AP from Perrin. I am not sure what was done to make it 'high altitude'. I did have one overboost on a Cobb 93 oct OTS map. I have run the Perrin map 99% of the time I have had the car. I have about 4.8k miles on an otherwise stock 08 STi. All AP firmware is current. I have had the SOA 'remap' done on the stock ECU.
I will be moving to a real Stage 2 (TBE, up/downpipes,CAI, FMIC, etc. + protune) but would like to not have this issue until that happens....
help?
bschweig is offline   Reply With Quote
Old 11-21-2008, 09:22 PM   #101
Fav Mod: Flat soled shoes
help?
Have you downloaded the new 1.02 maps from Cobb? Might help. I'm running an XPT stage 1 open source map here in Denver, and have had absolutely no issues.
linkbeat is offline   Reply With Quote
