Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Tires & Wheels
Old 02-28-2008, 02:03 PM   #1
Car: Silver 08 STI
Fav Mod: bald, smoking tires
IWSTI Addict since: Dec 2007
Default How to defeat the TPMS
Has anyone looked into defeating the TPMS system?
I run 3 sets of wheels and while its not THAT big of a deal id rather not stare at the warning light on my dash when im running my snow tires or my summer fun tires.
Apparently the reciever is under the carper near the drivers door, but thats all i know about it.
Any insight?
skark_burmer is offline   Reply With Quote
Old 02-28-2008, 03:08 PM   #2
Car: 06 Subaru WRX STi
IWSTI Addict since: May 2006
Default Re: How to defeat the TPMS
I dont think there is a way. besides going to the dealer and have them program the new tires.
Old 02-28-2008, 04:04 PM   #3
Car: 08 WRB STi
Fav Mod: Stage 1
IWSTI Addict since: Feb 2008
possible jury rig. obtain spare sensor, trick it to read ok pressure by adding a resistor across the pressure transducer contacts, place it in the glove box or under the seat. (not sure if you require four of them or not, or if the car auto detects the address for the transmitter). also you may try and remove the power wire to the receiver.
no tpms in Canada , I thought about this prior to installing my winter tires and then found out i didn't have to worry about it.
Good luck
BuzSTid is offline   Reply With Quote
Old 02-28-2008, 04:07 PM   #4
Car: Silver 08 STI
yeah, rather than dealing with hacking the senders i was going to focus on the reciever. I'll play with it this weekend, maybe it will be as easy as pulling the power... but likely not.
I expect it sends a go/no-go signal out so i just need to figure out how to set it to 'go'.
Old 02-28-2008, 04:19 PM   #5
Why not keep the senors in teh spare tire lol.
Old 02-28-2008, 05:03 PM   #6
Car: 08 STI, 05 Legacy
Fav Mod: dirt, grime and brake dust
As far as I know, you can't override the TPMS. A Subaru tech told me to put a piece of tape over the light.
I know that works with a CEL, but will the tape work on the TPMS?
Edvig is offline   Reply With Quote
Old 02-28-2008, 05:13 PM   #7
Car: White/Gold '08 STi
Fav Mod: Right foot
I dont think the glove box trick will work.. dont these things activate on movement/rotation?
Old 02-28-2008, 05:33 PM   #8
IWSTI Addict since: Oct 2003
Do you get a beep on startup if the TPMS fails, or do you just get the light on the dash?
Emissary is offline   Reply With Quote
Old 02-28-2008, 05:55 PM   #9
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
I think the easiest thing to do is get new sensors and install them. Someone found some for $40 or so each.
Old 02-28-2008, 06:03 PM   #10
That's a great price for the valves/sensors. At the dealer they are $72 a piece.
Old 02-28-2008, 06:40 PM   #11
Isnt it agains the law to disable them?
Old 02-29-2008, 04:37 AM   #12
IWSTI Addict since: Jun 2006
You also have to bring those new wheels to have the sensors reprogrammed in the cars computer. Every time you change your wheels.
Some Legacy guys have been taking apart the dash and putting electrical tape on the bulb.
Old 02-29-2008, 05:42 AM   #13
Trader Rating: (53)
I thought someone posted something her or on nasioc about how to do that yourself.
Old 02-29-2008, 07:40 AM   #14
Car: 07 Lexus IS250
Fav Mod: Future 09 STI Owner :)
Here is a good thread of how Lexus IS250/350 owners defeat the TPMS.
They go to home depot and make a "pipe bomb". You basically put all 4 TPMS sensors in this PVC pipe and you seal it and fill it up with air. Once you are done, you just put the pipe in your trunk and don't have to worry about it anymore since the ECU recongizes the sensors in the trunk.
Check it out.
DIY - TPMS Canister/Pipe Bomb - Club Lexus Forums
chmura is offline   Reply With Quote
Old 02-29-2008, 08:15 AM   #15
Fav Mod: Me.....
Check it out.
I cant wait until someone gets pulled over with this mod and the cops find the pipe bomb....
