Old 01-21-2008, 01:07 AM   #1
Car: 08 STI and 07 R6
Default 08 STI Nav/DVD lockout bypass?
Has anyone found a way to bypass the motion lockout on our Nav/DVD player?
doing some researching on the web and found this thread.. not sure if this applies. TIA.
AcuraZine Community - AVIC-N1 & N2 Motion Lock Bypass by Toggle Switch!
HRCboy is offline   Reply With Quote
Old 01-22-2008, 03:55 AM   #2
Default Re: 08 STI Nav/DVD lockout bypass?
Link didnt come up, but if you google forums for AVIC and/or Pioneer youll see a great forum for that particular NAV.
As for jacking around with your NAV, you may (or may not) run into some debate about it being right or not.
With that said, it essentially boils down to tricking the NAV that your parked.
Old 01-22-2008, 08:45 PM   #3
Car: 07 Lexus IS250
Fav Mod: Future 09 STI Owner :)
I have a new Lexus IS250 and there is a way to overwrite the NAVI. All you do is take out the NAVI unit and splice a wire and bypass a certain wire. Pretty simple to do.
This allows you to plays dvd's while in motion, input phone numbers, addresses, etc.
chmura is offline   Reply With Quote
Old 01-23-2008, 12:56 AM   #4
Sweet... thanks for the info... but where would be the best place to get this done? Or where would could I find more info on how to do it?
Old 01-23-2008, 04:00 AM   #5
A local stereo shop may. A voltmeter is all you really need in addition to knowledge of what the two wires are. Then again, it also depends on the states laws, or in your case province (?).
I think some people would be hesitant to spill the beans on exactly how to do it because unlike an exhaust or turbo swap, teaching someone how to bypass a security is a bad idea.
Old 01-23-2008, 03:10 PM   #6
Car: 08 wrx 07 sti
Fav Mod: 08 wrx
here you go
DIY: Bypass Nav (56k Warning)
turbobuick6 is offline   Reply With Quote
Old 01-28-2008, 06:38 PM   #7
Fav Mod: Prodrive pff7's and protune
Send a message via AIM to army STI Send a message via MSN to army STI Send a message via Yahoo to army STI
i know when my fgriend got one in her car she just had to pull the ebrake up till it clicked one time. after that it worked. it wasnt up enough to mess it up. id try that and see. other wise i have no idea.
army STI is offline   Reply With Quote
Old 02-19-2008, 06:38 PM   #8
Car: STI 2008
Were you able to figure out something??? I guess the car is still new eventually somebody will come up with a clean mod.. Still, it would be of great help if we could find the oem NAV wiring diagram... the STI DVD screen goes on and off as you stop and go... it doesnt not have to do with the e-brake...
blizzster is offline   Reply With Quote
Old 02-19-2008, 06:41 PM   #9
Car: 06 STI, 08 GSXR 750
Fav Mod: 8cm 20g
on my eclipse unit I just had to ground the parking brake sensor wire.
Hitman83 is offline   Reply With Quote
Old 02-19-2008, 06:48 PM   #10
Car: STI 2008
when you do that does your e-brake light on the dash stay on all the time???
Old 02-19-2008, 07:59 PM   #11
Fav Mod: 8cm 20g
No, you don't do anything to the ebrake wire at all. What you do is wire the e-brake sensor on the nav unit to any ground source instead of to the ebrake. I wired mine to the cd player ground. What this does is trick the nav unit into thinking you have the e brake set at all times.
Old 02-19-2008, 08:09 PM   #12
Car: STI 2008
that sounds sweet.. for the STI the DVD player works as long as the car is not moving even if the e-brake is on..
now is the matter of finding which is the correct wire...
Old 02-20-2008, 04:10 AM   #13
Car: 08 Dark Grey STi
Bluetooth and IPOD on 08 NAV head unit
serendipity is offline   Reply With Quote
Old 02-20-2008, 11:38 AM   #14
Car: Pure white MY08 STI
Originally Posted by serendipity View Post
I did it today
I connected the Gray wire to the Black wire in the center of the other plug!
I cutted the Gray wire and put another wire to the piece that comes from the radio and fixed it to the black.
It works perfect.
DO NOT mess with the switch of the handbrake!!!!
Sorry for my english,i'm from Belgium and i dont know al the technical words
suby555 is offline   Reply With Quote
Old 03-15-2008, 01:54 PM   #15
Car: STI 2008
Originally Posted by suby555 View Post
I did it today
It works perfect.
suby... does the nav system have a security code??? does it locks when you disconnect the car battery like some other factory radios???
