Old 09-30-2007, 03:44 PM   #1
Fav Mod: Pro-Tune
IWSTI Addict since: Apr 2005
Trader Rating: (17)
Default Front-end Popping and Snapping!
Mods:
Ohlins fixed perch struts, Cusco camber plates, Progress sways with Kartboy endlinks, GT Spec 3 piece subframe replacement set, GT Spec tie brace, NRG H-Brace, TIC fender braces.
I experience a continuous popping in the front-end while driving over various surfaces. I have lifted the car countless times, checking to make sure a brace is not snapped or if anything may have come loose. I have also loosened and re-tightened everything numerous times. Additionally, when I corner REAL hard, I get a really loud bang, like a bomb just went off in the front end. This is all very frustrating and unsettling.
Could the popping be the Ohlins? Do I have too much stiffness? Has anyone else experienced this?
Thanks for the help!
CB
Old 09-30-2007, 04:12 PM   #2
Car: 05 STi - Black
Fav Mod: No Lien
IWSTI Addict since: Mar 2006
Default Re: Front-end Popping and Snapping!
front sway bar hitting your tie rod?
Old 09-30-2007, 05:26 PM   #3
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
My vote is on the spherical bearings for the tophats.
Old 09-30-2007, 08:20 PM   #4
Fav Mod: Pro-Tune
Trader Rating: (17)
Yeah, thanks Clint, that is where my deduction is heading as well. Funny thing is, the sound appears to be down low. But, because everything is so tight and right everywhere, the source has to be something that is not so obvious. Thus, upon your urging, it is prolly the $50 Cusco camber plate that were supposedly "a great deal".
Any other suggestions?
CB
Old 10-01-2007, 01:11 PM   #5
Trader Rating: (53)
CB
possibly misrotated upper spring perch causing spring bind.
Old 10-01-2007, 01:22 PM   #6
Car: 05 S2000
IWSTI Addict since: Aug 2004
^^Yeah that. Sounds exactly like the problems I'm having... although not the loud bang. My right bearing is more worn than my left bearing, so when I take a hard left turn, you can hear it bouncing around and rumbling.
If you get to lift the car up again, check for play around the bearing. I bet you have some. I can pretty much move mine vertically a bit, which I've been told is very bad
Clint, I'm waiting for those Vorshlag plates!
eXstasy is offline   Reply With Quote
Old 10-01-2007, 09:03 PM   #7
Fav Mod: cusco zer2r's
IWSTI Addict since: May 2007
Send a message via AIM to dubs04sti Send a message via Yahoo to dubs04sti
Wow I was seriously about to post this same thing. I cant figure it out. At first i just got a small popping and grease everything up and made sure stuff was tight now and a couple nice bumps in the road is sounds just like you put it fast CB. I have cusco inverts, sways and plates. and soo on.. It sounds like muffled M-80s going off!~.. I cant figure the **** out!
dubs04sti is offline   Reply With Quote
Old 10-02-2007, 10:47 AM   #8
Car: 06 STI UGM
Fav Mod: (o)(o)
IWSTI Addict since: Jul 2006
Sounds like it might be something with the camber plates as both of you guys have them??
JAYMAC10 is offline   Reply With Quote
Old 10-02-2007, 10:59 AM   #9
Fav Mod: Pro-Tune
Trader Rating: (17)
Yeah, exactly. As the front end undulates over, say, a speed bump, it sounds like the front end is coming loose from the firewall.
I lubed the spherical bearings last night with some Slick 50 crap last night and it did not change the popping at all.
CB
Old 10-02-2007, 08:19 PM   #10
CB
I dont understand this.. I wish I just had a **** ton of cash laying around and I could jsut replace it with newer stuff
