Old 05-28-2004, 12:20 PM   #1
IWSTI Addict since: Jul 2003
Hey guys,
My Eibachs are on their way - just wondering about the install,
from anyone that has done it so far.
Any tricks to know ? Do the bump stops need to be cut down ?
Anything else I should do at the same time ?
As usual, all help is appreciated...
-SB
SportyBry is offline   Reply With Quote
Old 05-28-2004, 01:35 PM   #2
Car: 2004 STi
IWSTI Addict since: Apr 2003
either camber plates of hardened strut tops will make a huge improvement, especially if you get a sport alignment with some negative camber of caster adjustments.
Old 06-01-2004, 07:18 PM   #3
IWSTI Addict since: Mar 2004
I installed eibachs and it went very smoothly I did no addl mods the car dropped perfectly, I like the way it drives better then with the stock springs also. I havnt gottent aligned yet becuase its driving perfectly straight. Maybe I just got lucky there but I will get the aligment done eventually
rbsti is offline   Reply With Quote
Old 06-01-2004, 07:21 PM   #4
Fav Mod: Stealth mode
IWSTI Addict since: Nov 2003
No, don't trim the stops. And while hardened mounts will improve strut performance, you will find a significant improvement with just the springs.
Snax is offline   Reply With Quote
Old 06-01-2004, 09:16 PM   #5
IWSTI Addict since: Aug 2003
Anyone know the exact spring rates on the eibach pro kit springs? The 2004 springs aren't listed on the ravensblade site...
Edit: From a few posts down: 234/229 seems to be the rate.
RabidDog is offline   Reply With Quote
Old 06-12-2004, 04:01 PM   #6
Car: Solo II, WRC
IWSTI Addict since: Oct 2002
Send a message via AIM to CloNeGTS
I could have missed it....but I don't recall seeing bump stops when doing my spring install..... ????
CloNeGTS is offline   Reply With Quote
Old 06-12-2004, 06:45 PM   #7
IWSTI Addict since: Jan 2004
Unless you removed the strut cover you wouldn't see the bump stops. They help keep the shock from fully compressing which is not only bad for the shock but bonejarring as well.
I had to cut the ones in my Civic due to the 2" drop
Boxer is offline   Reply With Quote
Old 06-12-2004, 07:33 PM   #8
Car: 06 cgm sti w/ppg dog
Fav Mod: RIP 04 psm sti
IWSTI Addict since: Sep 2003
Send a message via AIM to nhsilversti Send a message via Yahoo to nhsilversti
there were NO bump stops on my struts.
ted
nhsilversti is offline   Reply With Quote
Old 06-12-2004, 08:23 PM   #9
IWSTI Addict since: Apr 2004
It is an inverted strut. You aren't going to see the bump stops because they are inside the strut body!
MeoW71 is offline   Reply With Quote
Old 06-13-2004, 09:46 AM   #10
Sportybry,
Can you post some pics of your STi with the Eibachs? I just ordered a set and would like to see the drop. Did you also do the hardened strut mounts? If so, who has the best price right now?
Thanks,
Karl
KSTi is offline   Reply With Quote
Old 06-13-2004, 11:42 AM   #11
I haven't installed them yet. Going to stick with the standard strut-tops, too.
Next weekend is D-Day, or rather E-Day !
Old 06-13-2004, 04:40 PM   #12
Car: Solo II, WRC
I'm fully aware of what bump stops are and what they are for.....and I removed the dust cap on every corner....no separate bump stops on my struts!
Old 06-13-2004, 04:41 PM   #13
Car: Solo II, WRC
Not sure if that's true or not either....a bump stop would have exactly the same function regardless of whether the strut is inverted, would it not?
Old 06-13-2004, 05:58 PM   #14
IWSTI Addict since: Jan 2003
Send a message via AIM to CreoWRX
He means that you have to remove the strut from the strut housing (nut on the bottom of the strut body - the red part), and once you do you will see the bump stop on the shaft. Since the strut is inverted (basically upside down), the shaft is at the bottom (inside the strut housing). The dust covers are actually over the strut body portion.
-Mike-
CreoWRX is offline   Reply With Quote
Old 06-15-2004, 12:34 PM   #15
Car: WRB STi - WRR 92X
So nobody trimmed their bump stop?
COnfirm please..
GF210 should get installed soon.
salaki is offline   Reply With Quote
