Old 09-24-2007, 02:04 PM   #16
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
Default Re: sway bar; how much difference?
swaybars= grin from ear to ear....especially those 1st and 2nd gear power slides, but bottom line yes a must have modification that is well worth it
B4RSTiwsnc is offline   Reply With Quote
Old 09-24-2007, 02:51 PM   #17
Car: 06 sti wrb
Fav Mod: trading the svt for an sti
what size are the sways in cobb`s kit?
the ambush is offline   Reply With Quote
Old 09-24-2007, 03:26 PM   #18
Trader Rating: (50)
I believe they are 25mm, but they are also hollow so that gives them an effective diameter of somewhere around 22-23mm IIRC.
Remember, you have to run the math on hollow vs solid bars or you won't get a direct comparison.
Old 09-25-2007, 08:02 AM   #19
Car: 06 sti wrb
i cant find the text now, but i`m pretty sure i read on there old website that the hollow design made the bar stiffer !?
Old 09-25-2007, 09:00 AM   #20
NASIOC Spy
Car: 1991 MR2, 2003 WRX
Fav Mod: seat time
I don't think you read that
ButtDyno is offline   Reply With Quote
Old 09-25-2007, 09:04 AM   #21
No Rice
Car: 06 OBP STi
Fav Mod: Brake dust
thanks a lot for the info guys!
Seppo is offline   Reply With Quote
Old 09-25-2007, 09:27 AM   #22
If the Cobb bars are anything like Hotckis (and from the picture, they're not the same), the rates are here.
The Hotckis front bar is like 23.3mm and rear 24.4mm, IIRC. Cobb uses more bends up front (and necks down in diameter at the start of the bends) so it's almost certainly a little softer.
Old 09-27-2007, 10:44 AM   #23
Car: 07 SWP STI
Fav Mod: Strength Shoes
Yes. For his use - street only the front bar will make for smooth and predictable direction changes. This is the same reason I recommend it for guys who road race on occasion.
The rear bar I suggest because he's still on stock springs. 24mm in my opinion is too large for stock springs, but with the 22mm adj. he'll be able to bump up to 24mm when/if he gets stiffer springs.
I've got an essay on this subject somewhere around here.
would it be ideal to just get 24mm adj front and rear? you could adj the rears to 22mm but still have the option of bumping up to 24, and even 26.
edit: assuming you have stock springs etc.
STI23 is offline   Reply With Quote
Old 09-27-2007, 12:03 PM   #24
Car: 07 Impreza WRX STI,
Fav Mod: Track days!!!
Send a message via AIM to GoodTimes
What's the stock sway bar size front and rear?
GoodTimes is offline   Reply With Quote
Old 09-28-2007, 05:40 AM   #25
Car: 05 STi, OBP
Fav Mod: Agile Protune
Send a message via AIM to xlsupreme
It's actually just a rotational stiffness thing. most of the ability of a shaft to resist twisting is in the outside "layer" of material if you will. The inside material of a shaft doesn't do as much to help quell rotation, but a hollow shaft is substantially weaker than a solid shaft of the same size, loaded in rotation..
if you're mathy, and would like to crunch numbers, the formula for shaft twist is
twist (radians) = TL / JG, where T is torque, L is length of shaft, J is polar moment of inertia (gemoetry based, the biggest thing that resists angle of twist, in our application) and G is a material property, think of it as a spring constant.
If we're comparing the two swaybars, it's likely that they will be the same size, of the same material, and have the same forces on them. That takes T, L, and G out of the equation.
J for a solid shaft is π*D^4 / 32 where D is diameter.
J for a hollow shaft is π*(OD^4 - ID^4)/32
Polar moment of inertial isn't the only thing to consider, mind you, but it's the simplest, and will get you most of the way there. Using those formulas you can determine how big the OD of the hollow shaft will have to be, and it's required wall thickness to resist twisting as well as a solid shaft of a specific diameter.
xlsupreme is offline   Reply With Quote
Old 09-28-2007, 08:22 AM   #26
Car: 07 SWP STI
On the nasioc swaybar FAQ it says
Most of the turbo Imprezas come with a 20mm front swaybar and a 13-20 (??) mm rear swaybar.
Jayli is offline   Reply With Quote
Old 10-02-2007, 09:35 AM   #27
Car: Silver Euro 07 STi
hi,
I have a stock 07 STi and I want to buy WL swaybars and will buy coil over later. I will use the car in race tracks and street, i don't like undresteer. What size and other supporting suspension upgrades do you suggest? Thanks
They will make a big difference in the handling of the car. If you'd like some suggestions on sizes just let us know.
Old 04-28-2008, 11:33 PM   #28
Car: 07 Subaru WRX STi
heh i dont know should i got a Sway Bar first then Coilover or the other way around???
Im looking at Cobb F/R Standard Sway w/ Kartboy Endlinks..are they a good combo???
Slow.STi is offline   Reply With Quote
Old 04-28-2008, 11:53 PM   #29
^ Those are a VERY good combo. Not in a biased way either Awsome rigidity, longevity and fitment is perfect. I highly recomend the KB endlinks also, their just a little noisey. I would alwase recomend sways first, just to get the feel of less body roll. Coilovers will just add to the cornering abilitys in a pleasent way.
Old 04-29-2008, 01:10 AM   #30
thanks
one more question: do i need aligment for sway bar???
