Old 09-09-2007, 08:27 AM   #1
Car: white06
Default setup question
sorry for another one but I have been trying to decide how I want to upgrade the suspension on my 06STi, but the more I read the more confused I get. My car is a daily driver but I am not too concerned with ride quality. I would like to get into autox. I just want a simple setup that is a improvement over stock, but not spending thousands of dollars. Looking to spend around -1k.
-27mm front/ 24mm rear whiteline sb
-kartboy or whiteline endlinks (any suggestions on which one)
-Springs?
I want springs, I was really looking into the rce yellow springs..... but I read they are having problems with creaking. how bad is the noise? If the noise is the only problem, the preformance, from what I hear, is great.
No one ever has problems with Prodrives, but I like the look of the yellows a lot better. What about racecomps lowering camber plates with prodrives. anyone have that setup? would it be worth the xtra $400
- an alignment after all is installed
any other suggestions?
Thanks
theBrick714 is offline   Reply With Quote
Old 09-09-2007, 12:31 PM   #2
Car: 06 wrx ltd vf34
Fav Mod: JTAG
Default Re: setup question
this is what i have
i have front kartboy rear whiteline
-Springs?
I have rce v2 yellow.. yeh..mine creaking in low speed.. but i dont care anymore.. i like the performance of it.
very important.. max neg camber in front. and get a camber bolt in rear to adjust
bzbuzz is offline   Reply With Quote
Old 09-09-2007, 03:58 PM   #3
Car: white06
would you recommend that setup? Is there a reason you went with different endlinks?
