Old 08-27-2007, 09:18 PM   #1
Car: 06 STI
IWSTI Addict since: Nov 2005
Default Alignment by the dealer ..
Hey I just got re-aligned and was wondering what you guys think of these numbers. I'll post before numbers and than after numbers.
Before:
Front Left|Front Right
Camber: -0.7|-0.8
Caster: 5.0|4.0
Toe: -0.44|-0.48
SAI: 8.0|7.4
Included Angle: 7.3|6.6
After:
Camber: -0.7|-0.7
Caster: 5.0|4.0
Toe: -0.02|0.06
SAI: 8.0|7.3
Front:
Actual|Before
Cross Camber: 0.0|0.1
Cross Caster: 1.0|1.0
Cross SAI: 0.7|0.6
Total Toe: 0.03|-0.92
Rear Before:
Rear Left|Rear Right
Camber: -1.0|-1.7
Toe: -0.13|0.19
Rear After:
Camber: -1.3|-1.7
Toe: 0.02|-0.04
Rear
After|Before
Cross Camber: 0.4|0.4|
Total Toe: -0.02|0.06
Thrust Angle: 0.03|-0.16
DragonXero13 is offline   Reply With Quote
Old 08-27-2007, 09:53 PM   #2
I'm Jim Halpert
Fav Mod: EWG
IWSTI Addict since: Apr 2006
Default Re: Alignment by the dealer ..
i really dont know much about alignments but after talking to darin for a while at west end, it seems like ur alignment is pretty standard. He made my front -1.25 degrees. He told me that negative 3/4 of a degree is what pretty much everyone gets so i guess they gave u an average joe alignment
Old 08-28-2007, 04:57 AM   #3
Car: 05 STi - Black
Fav Mod: No Lien
IWSTI Addict since: Mar 2006
How did he adjust the rear camber? Do you have bolts or plates?
Old 08-28-2007, 10:58 AM   #4
Car: 06 STI
Nothing, all my suspension mods are Swift Springs, WL Sways with KB EL.
Old 08-28-2007, 11:08 AM   #5
this space for rent
Car: 04 psm sti
Fav Mod: custom 03 seats
IWSTI Addict since: Jul 2006
i would go back and specify that you would like the numbers to be more even especially for your rear camber and the toe, have them zero out the toe all the way around and tell them you want your rear camber to be even on each side like the front or at least +/- .-1 degrees
sti-liger is offline   Reply With Quote
