| Amateur STI Driver | 06 STi. I did a search and it looks like I may have the loose axle deal going. If I let off the gas quickly, I hear a loud pop in the back, about the middle of the car and towards the bottom of the car. It is easily repeatable. I don't think it's swaybar related as it makes the noise with the stock bar and also my Whiteline (forgot to try it without the bar on the last changeover, but noise is same with both bars). Is there any trick to tightening the axle nuts besides buying a 32mm socket? I've read 140 ft.lbs. torque? Any other ideas? I seems to be getting worse. Thanks Whoops, maybe this should be in drivetrain forum? This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by wrxpappy; 08-23-2007 at 08:46 AM. |
| | #2 |
| Authorized Vendor | fronts are a different torque, but the way you are describing it I don't think it's axle nuts. What mods are done to your car |
| | #3 |
| Amateur STI Driver | I just have front Whiteline (27-29 set at 29) and back whiteline (set at stiffest, but I run the stock bar at autocross for A/S). Ferrodo 2500 pads, that's it. Around 12,000 miles. |
| | #4 |
| Junior STI Driver | i just had an axle replaced for the same, reproduceable noise...thought it was a strut and got 2 of those for free too!!! and they tightened the whole subframe while they were at it. unbelievable how much the car loosens up over time!!! |
| | #6 |
| Junior STI Driver | ya...i didnt complain....they just did it...under warranty...i dont know if tightening it would help...i dont know what it looks like under there to help ya ...sorry! |
| | #7 | |
| S204 Racer Car: 2006 STI Fav Mod: Recaros Location: Mahan, OR Posts: 2,904
IWSTI Addict since: Sep 2005 Trader Rating: (1) | Quote:
Also, an easy way to tell if it's axle related is to roll down your windows and do back and forth testing in a parking lot. You can actually do it without moving by setting the parking brake and slipping the clutch a little in 1st and reverse, and you'll hear the axle clicking as it takes up the slop in either direction. I had one of my rear axles replaced under warranty at about 25K miles because the axle nut had worked loose half a turn. It's the only thing that has ever gone wrong with my STI (knock on wood -- the basic 36K warranty is up in 1000 miles). | |
| | #9 |
| Senior STI Driver Car: 05 CGM STi Fav Mod: Seat Time Location: Tulsa, Oklahoma Posts: 351
IWSTI Addict since: Jun 2005 Trader Rating: (1) | My car (2005 with 31K miles) is starting to do the exact same thing. I've got a two day Auto-x coming up this weekend too. I'll be going a bit light on the launches I suppose. |
| | #10 |
| Amateur STI Driver | Well, to me, this got a little stranger tonight. I bought the 32 mm and thought I'd give it a tug. I pulled the right side off (I was thinking the noise was on the left side) so I just put the wrench on and wiggle back and forth to see what it should feel like. I didn't release the lock thing at all and everything was very solid and secure. I got on the left side and was bending my cheapy screwdriver and needle nose trying to bend the lock tab back so I went ahead and threw the wrench on and the big nut turned, with the lock tab still in position. I tightened to 140 ft/lbs and the sound is gone. I'm glad the noise is gone, but without re-positioning the lock tab, something doesn't seem right. I would assume it will back itself out again. Weird.... |
| | #11 |
| Halliburton Mercenary | humm.... i have this same noise, but haven't really done anything about it. where is said axle nut and how can I check and see if it is loose? is this the nut behind the wheel that holds everything together and has the piece pushed into it? |
| | #12 | |
| | #13 |
| Halliburton Mercenary | Great- wonder what a new axle costs... My driver's rear was about 2-4° loose. I tightened it up and during a short drive it seems to be gone... for now. |
| | #14 |
| Platinum Member Car: 06 STI UGM Fav Mod: (o)(o) Location: Kelowna Posts: 1,140
IWSTI Addict since: Jul 2006 Trader Rating: (0) | I think I have this same problem! I'm going to check the axel nuts tonight and see if the sound goes away... If it does then comes back, I'll take it to the dealer to be fixed under warranty! Jay |
| | #15 |
| STI Driver | hmm I've been having something that might be this, but it's intermittant. I'll try torqueing it down tonight, thanks MUCH for this suggestion - I've been tightening down about everything else trying to get it but didn't think about the axle nut. This ad is not endorsed by this member. Please register or login to hide this ad. |
