Old 07-31-2007, 01:23 PM   #1
IWSTI Addict since: Apr 2007
Default rotating strut tops
Ok I've been searching all day long for any info about this. I've read one reference to it but no real info. Is there any alignment benefit to rotating the strut tops? Will the 3 bolts even line up in any other way? Just trying to find any cheap way to get more castor/camber.
Dark_Helmet is offline   Reply With Quote
Old 07-31-2007, 01:27 PM   #2
Fav Mod: Driving School / Trunk swap (no attention ftw)
IWSTI Addict since: Sep 2006
Default Re: rotating strut tops
no - the confusion is that you can swith the RCE camber plates from side to side for a little added caster. Someone mistakenly said you could just rotate them, but IIRC thats not the case.
J
mgsm666 is offline   Reply With Quote
Old 07-31-2007, 02:35 PM   #3
cpa
IWSTI Addict since: Oct 2003
Or have them redrilled for a different orientation.
cpa is offline   Reply With Quote
Old 07-31-2007, 02:47 PM   #4
Car: '06 STI
Fav Mod: air freshener!!!
IWSTI Addict since: Jan 2006
Swapping several brands top plates will yield more caster but it wont effect the camber. I remember hearing that it wasnt a win-win deal tho, there are some trade offs but I dont remember what.
Old 07-31-2007, 03:42 PM   #5
Car: 2006 STI
Fav Mod: Recaros
IWSTI Addict since: Sep 2005
Less total camber available, and a static relationship between camber & caster, since the plates are only single adjustable.
Speaking of which, does anybody make double adjustable plates for the STI? Kinda like most all the plates available for Mustangs. Caster & camber both, independently adjustable.
