Old 07-31-2007, 11:52 AM   #1
Fav Mod: Steering Rack Bushings, Rubber, and Camber Plates
IWSTI Addict since: Jun 2005
Send a message via AIM to S1MPSONS
Default My Alignment Specs: For Review, Comments, Opinions & Suggestions
The car is primarily for weekend fun, specifically autox with some light street duty. I'll be able to comment better on this setup after the autox this friday, Aug 3rd.
-Whiteline Steering Rack Bushings
-Whiteline 27-29mm Adjustable Front Sway Bar
-JDM Pink Springs
-Cusco Front Camber Plates
-Cusco 22-24mm Adjustable Rear Sway Bar
-Hotchkis Rear Adjustable Endlinks
-Hotchkis Front Adjustable Endlinks
-17"x7.5" USDM STi Silver BBS with 245/45/17 Falken Azenis RT-615 (For SCCA)
-17"x8" Graphite Rota Torque with 255/40/17 Kumho V700 Victoracer R-Comps (For all other Autox Orgs)
S1MPSONS is offline   Reply With Quote
Old 07-31-2007, 12:05 PM   #2
Fav Mod: Driving School / Trunk swap (no attention ftw)
IWSTI Addict since: Sep 2006
Default Re: My Alignment Specs: For Review, Comments, Opinions & Suggestions
its official...you hate your tires
mgsm666 is offline   Reply With Quote
Old 07-31-2007, 12:13 PM   #3
Halliburton Mercenary
Car: AW GDF-D
Fav Mod: Q-Rack
IWSTI Addict since: Oct 2005
Trader Rating: (12)
Looks good. I have one suggestion for your next alignment:
Run less everyday camber (~-1.75 to -2°) and then add a degree for auto-x days. 3° is good for auto-x, but a bit much for the street. The added toe (from adding negative camber) will help turn in, also.
Old 07-31-2007, 12:22 PM   #4
Genius. I wish I tought about that before I did the alignment. If I go to my camber plates and back them off from full negative to "0" or the neutral setting, will that create toe in? If so, thats probably worse for tire wear than the current settings, right?
Old 07-31-2007, 12:38 PM   #5
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
Adding camber (adding +) should add positive toe. Reducing (adding -) should add negative toe.
That is how it worked on my PDE plates in the caster/camber setup.
Old 07-31-2007, 12:39 PM   #6
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
Yes and yes.
Old 07-31-2007, 01:27 PM   #7
I guess I won't mess with it then. Not until the next alignment.
Old 07-31-2007, 07:07 PM   #8
Car: 06 Aspen White w. Go
Fav Mod: teH Muff
IWSTI Addict since: Apr 2006
I always thought you were running the cusco coilovers. Guess the plates threw me off.
Who did the alignment?
uncle lewie is online now   Reply With Quote
Old 08-01-2007, 06:25 AM   #9
Alex at Sears Auto Center at Paramus Park Mall
