Old 07-19-2007, 09:26 AM   #1
is, in fact, a lolcat.
Fav Mod: banhammer
Default The STi Suspension Depot
Since there's a lot of confusion out there about what suspension setup does what, I think we should take the first step in cataloging the existing bits. Thus, in this thread, we're going to gather info regarding coilovers/struts/springs for the STi (please submit stats separately for struts and springs). The information will be gathered into a single post. Please contribute whatever you can via PM, and be prepared to prove your information.
Please include all of the information you can (again, please do so in a PM). If you have suggestions as to what should be included, please let me know! Here's an example of the format:
Cheapo Craptastic Coilovers
Type: Coilover
Spring Rate F/R: 300/230
Drop F/R: 30mm/15mm
Bump Travel (Spring): ???
Bump Travel (Strut @ what ride height):
Droop Travel: ???
Strut Manufacturer: Cheapo
Spring Manufacturer: Cheapo
Purpose: Aesthetic
MSRP: $1200
Stocked by: ???
Compatability: 04+ STi
Adjustability: No.
Extras: None.
Notes: Springs are linear, bump stops are 2 inches long front and back.
Notes: These are proven to coil bind and the dampers really suck.
Any help is appreciated!
=====COILOVER DEPOT=====
Öhlins Flag Series
Type: Coilover
Spring Rate F/R: 450/355
Drop F/R: separate height and preload adjustments
Bump Travel: 105mm
Droop Travel: ???
Strut Manufacturer: Öhlins
Spring Manufacturer: Eibach
Purpose: Track/Auto-X
MSRP: ~$4300
Stocked by: Turn in Concepts, RallySportDirect, Racecomp Engineering,
Compatability: 04 Sti version & 05+ STi version
Adjustability: Compression and Rebound separately
Extras: Front camber plates, rear pillow ball mounts, dual-height adjustable, rear adjusters built-in
BC Racing BR Series Coilovers
Type: Coilover
Spring Rate F/R: 8k (448lbs)/6k (335lbs)
Bump Travel: 3.7 inches off the car
Droop Travel: very little, maybe 2 inches.
Strut Manufacturer: Bor Chaun Racing
Purpose: Street/Light Track
MSRP: $1000
Stocked by: Import Image Racing
Adjustability: 30 way single adjustable
Extras: Front camber plates, rear pillowball plates. Optional rear camber plates and rear adjuster extenders.
RCE Tarmac 2
Type: Coilover
Spring Rate F/R: 9k (500lbs)/7k (400lbs) NOTE: They offer three spring rates.
Drop F/R: ?
Bump Travel: ?
Droop Travel: ?
Strut Manufacturer: KW
Spring Manufacturer: KW?
Purpose: Street/ Track
MSRP: $1895
Stocked by: Racecomp Engineering
Adjustability: Rebound, Bump/Compression, Ride Height
Extras: Stainless steel dampers mated to linear race springs, separate compression and rebound adjustments, composite locking perches with safety perches added, piggyback reservoirs on front dampers, helper springs.
Endura-Tech Coilovers
Type:
Coilover
Spring Rate F/R: 392/280 (7k/5k)
Drop F/R: 2.0" / 2.2"
Bump Travel: ?
Droop Travel: ???
Strut Manufacturer: ?
Spring Manufacturer: NHK Spring
Purpose: Daily Driver w/ occassional track use
MSRP: $1873 (WRX) $2211 (STi)
Stocked by: P&L Motorsports, Pacific Import Auto, PRE, DCH Motorsports, TopSpeed
Compatability: 02-07 WRX, 04 STI and 05+STi
Adjustability: 10-way rebound adjustable
Extras: Front Camber Plates, Pillowball upper mounts, seperate lower bracket height adjustment, pre-loaded springs.
AWAITING INFORMATION: RCE Tarmac2s, Whiteline G4s, TienSSPs, KW V3s, ZZYZXs, Meagan and many more.
=====SPRING DEPOT=====
RaceComp Engineering (RCE) Yellow Springs (V2)
Type:
Spring (Progressive)
Spring Rate F/R: ???
Drop F/R: 23mm/20mm
Bump Travel: N/A
Droop Travel: N/A
Strut Manufacturer: N/A
Spring Manufacturer: RaceComp Engineering
Purpose: Street/Track
MSRP: $314
Stocked by: RaceComp Engineering/GTworx
Tanabe 05-06 Spec GF210
Type: Spring (Progressive)
Spring Rate F/R: 5.8 / 4.4
Drop F/R: 1.0 / 0.5 inches (on 05 struts...compatible with 04 struts, but with different drop).
Bump Travel: N/A
Droop Travel: N/A
Spring Manufacturer: Tanabe
MSRP: $280
Known problems: Peeling/chipping paint. Fixed in later 05's.
Tanabe 04 Spec GF210
Spring Rate F/R: 4.3 / 4.0
Drop F/R: 1.3 / 1.0
Bump Travel: N/A
Droop Travel: N/A
MSRP: $260
04 Swift Sport Mach Springs
Spring Rate F/R: 140-252 / 90-224
Drop F/R: 1.0 / 0.8
Bump Travel: N/A
Droop Travel: N/A
Spring Manufacturer: Swift
MSRP: $279
Known problems: None.
05 Swift Sport Mach Springs
Drop F/R: 1.2 / 1.2
Bump Travel: N/A
Droop Travel: N/A
MSRP: $279
AWAITING INFORMATION: Tien, Eibach. Prodrive, RCE Blacks, STi Pinks and many more.
Old 07-19-2007, 10:44 AM   #2
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
Default Re: The STi Suspension Depot
We're going to keep this thread pruned of posts so that all the information is found in the first post. Easier to keep track of all of the random information that way...
Try to keep the chatter to a minimum in here please. Post if you feel the need to correct some of the information in the main post.
Old 07-20-2007, 05:23 AM   #3
Fav Mod: banhammer
Bump. C'mon folks. PM me. Let's get this catalog built!
Old 07-20-2007, 07:05 AM   #4
Fav Mod: banhammer
Tanabe info added.
Old 07-20-2007, 12:33 PM   #5
Fav Mod: banhammer
Swift info added.
Old 07-23-2007, 08:44 AM   #6
Fav Mod: Brum Brum
2007 Postwhore King
Do you want me to delete your old bumps routinely? EDIT: You can do that yourself if you want, never mind
Old 07-23-2007, 08:48 AM   #7
Total travel is 105mm inches for the Ohlins, not just bump.
I PM'd you the detailed specs of the Whiteline coilovers, except apparently they switched to 220mm front springs.
Old 07-23-2007, 08:57 AM   #8
Fav Mod: banhammer
Try and put it into the formula above. I don't have the time to reformat it, and I don't want to misinterpret your message.
Old 07-31-2007, 10:04 AM   #9
Fav Mod: banhammer
Bump for more entries.
Old 08-01-2007, 12:48 PM   #10
Type:
Coilover
Bump Travel: ?
Droop Travel: ???
captainj2000 is offline   Reply With Quote
Old 09-11-2007, 06:30 PM   #11
Fav Mod: banhammer
Holy smokes, I'm behind on my updates and bumps! I'll get to this tomorrow. Bumping for more info.
