Old 07-06-2007, 09:49 AM   #1
Car: 05 Subaru WRX STi
IWSTI Addict since: Jan 2006
Default what's your autox setup?
I'd like to know what people are setting their suspension settings at?
I'm talking things like ride height, camber, caster, toe, rebound, compression, swaybar, etc... (and anything I'm forgetting).
I know that 'it depends on what kind of suspension you have'... so tell me what suspension you are running?
The only setting I've messed with right now is -2.5 camber in the front, -1.5 in the rear, and 0 toe for my BSP class STi.
vampyr is offline   Reply With Quote
Old 07-06-2007, 04:36 PM   #2
Car: 05 STi OBP
Fav Mod: KW Variant 3's
Default Re: what's your autox setup?
My Neutral set up with KW's
that is all
VAN
vandersti is offline   Reply With Quote
Old 07-06-2007, 04:39 PM   #3
Car: 06 Subaru STI
Fav Mod: ohlins
IWSTI Addict since: Aug 2006
06 STI
-2.5 degress camber up front -1.8 out back, 0 toe all the way around.
Whiteline 29mm up front 24 out back
RCE Yellow springs
RCE non-lowering camber plates
ravenwrx is offline   Reply With Quote
Old 07-06-2007, 06:31 PM   #4
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
well, i don't run auto-x (might start though) but when i do my setup will be
05 STi
Ohlins Sportline Coilovers
F: -2.6 deg camber, 1/16 toe out, Whiteline 26mm sway (would probably set it to 24mm), 6 clicks from full hard bump
R: -2.2 deg camber, 0 toe, 22mm Whiteline rear sway 8 clicks from full hard bump
Stock wheels and tires,
the coilovers will probably put me in some insane class but whatever.
Old 07-06-2007, 06:34 PM   #5
Fav Mod: T2s and Recaros
IWSTI Addict since: Oct 2005
http://www.iwsti.com/blogs/twisties/...+2005+STi.html
-2 camber all around, 0 toe all around.
going to redo the front plates hex screws and get more negative camber up front. i'm on the RE070's.
Old 07-06-2007, 06:44 PM   #6
Car: 05 STi WRB
Fav Mod: Driver's school
Send a message via AIM to Splash Send a message via Yahoo to Splash
Heh, no higher than Street Touring Ultra... (1 up from stock)
Now, replace that turbo and the insanity starts... <grin>
Splash is offline   Reply With Quote
Old 07-06-2007, 06:57 PM   #7
Car: 05 WRB/Gold
oh ok, STU isn't that bad. Are R-comps allowed in it?
Old 07-06-2007, 07:13 PM   #8
Car: 2oo8 aw STi
No, the class was started to allow common mods w/o the added expense of R-comps.
For R's go back to AS, or up to BSP.
fwiw, I'm running AS w/Ohlins fixed, big Whiteline FSB, 275/40 V710s, whatever camber I can get, I forget how much.
Old 07-06-2007, 07:22 PM   #9
Car: White, '06 STi
Fav Mod: Staying stock
A-stock STi
Brakes: carbotech ax6 pads front and rear, no ABS, still my original rotors (car is only really driven to/from autox and track)
front: max camber from the stock adjusters (*maybe* 1 degree and change ) 3/32 total toe out
rear: 1/16 total toe out (sometimes more) No camber adjustment
275mm V710's on a second set of stock wheels, 5mm spacer in the rear. ARP studs all around with open lugs
G-force 4 pt harness clipped into G-force eye bolts on the bottom and the child seat anchors for the top
(for people that worry about the fifth point and keeping the lap belt on your pelvis, try pumping down the seat, buckling in, getting it snug, then pumping it back up, it's nice, and really quick to get in and out because you don't have to re-tighten the harness every time, just pump the seat! )
Stuff I fabbed:
Custom 29+mm front sway, and heim joint endlinks, poly bushings in stock brackets
HKS muffler and resonator-less full mandrel bent 3" catback (I just bought the muffler and did the piping)
Tons of cone marks
ocassionally brilliant, occasionally crap-tastic driver :P
The car is an autox beast. I think it's awesome that you can run down a super stock vette's raw time on alot of courses where they can't use all the power!
Niles is offline   Reply With Quote
Old 07-07-2007, 08:38 AM   #10
Fav Mod: v710's, C16
IWSTI Addict since: Aug 2005
04 sti
zeal V6 8/6 full stiff
-3.0 (f) 3/32 toe out
-1.9 (r) 0 toe
whiteline 29 (f) 24 (R)
245-45-17 v710's (AX)
shaved re070 or 245-40 hoosier R6 (track)
rays 8.5 +40
carbotech xp-8's
racing brake rotors
Russel SS lines
super blue
mesa50w is offline   Reply With Quote
