| | #106 |
| Sooper Moderator
Car: 06 SGM STI Fav Mod: Stage 1 Location: San Diego Posts: 3,890
IWSTI Addict since: Mar 2006 Trader Rating: (7) | so does this mean that we who have the older version of the yellows get a replacement set free of charge or at a great discount??? maybe??? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #107 |
| Junior STI Driver | yikes, I stop reading IWSTI for a few weeks and come back to this....if I recall correctly, the Yellows were the "cat's meow", there was a fairly large thread on them, and everyone was jumping on the bandwagon. Hell, I even swapped out my Prodrive springs to try the Yellows. |
| | #108 |
| Professional STI Driver Car: 06 Aspen White STi / Location: Plano, TX (Dallas) Posts: 464
IWSTI Addict since: Jan 2006 Trader Rating: (0) | I swear I theorized to this a long while back when doing my initial basic knowledge research on springs. In fact coild stacking/binding and them doing so on large bumps was THE reason I went with JDM Pinks vs. RCE springs when I finally bought some. Not a rib toward RCE springs at all, but after driving on some I felt exactly what my Prodrive WRX springs when they bottomed out on large bumps, and it was confirmed when I looked up into the wheel well and while it was on the lift and saw evidence. For me, although they handled great, I didn't care for the way they handled large bumps... I guess the binding was the reason. That said, I don't think anyone should see this thread as a doomsday topic for springs and don't let this scare you out of a spring decision... rather add to you knowledge about the parts you're putting on the car. |
| | #109 |
| Junior STI Driver | So stretch I think this leads to a much more serious problem...why on earth havn't you manufactuered your own god damn spring yet ! Seems like just about every informative suspension thread was been written by you so if anyone knows there **** it is you. Also major props to RCE for standing behind their product and correcting the issue pronto. How many other spring manufacterers are in this forum looking at customer feedback taking it in and solving the problem first hand. Seems like RCE was singled out in this thread much more so then all the other manufacterers that had the exact same problem, yet they handled it very professionally. |
| | #110 | |
| Silver Member
Car: Aspen 2005 STi Fav Mod: TurnInConcepts Coilovers Location: Silver Spring, MD Posts: 1,865
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Quote:
![]() I've posted this several places, but here's the Stretch-spec spring setup:
Ground Control may sell exactly this setup. I've read their camber plates raise the upper strut mounting point nearly an inch, and obviously you can get whatever spring rates and ride height you want. You could make your own stretch-spec setup. Buy 8", 275# springs front and 8", 225# springs rear. I personally ran the springs without the camber plates, which means I didn't run the most important part. I now run their coilovers but I'm still on the Group-N tophats, shame on me. I did hear a rumor about forthcoming non-lowering springs for the STI. I think those (if the rumors are true), combined with RCE's lowering camber plates would be another good setup. I think less is more when it comes to lowering unless the strut can support it. For that reason, I also think RCE's Black's will outperform the Yellow's in every way. On aftermarket struts that may change, but honestly, I think coilovers are just the easiest solution. You can get Koni/GC or Bilstein coilovers pretty cheaply and that gets you much firmer springs, more damping, more travel, and the ability to run more camber. I think there's a stigma that coilovers are all stiff or uncomfortable. There's absolutely no difference between a "coilover" and a matched spring/strut set other than the threaded spring perch. That's it. Anyway, I'm rambling. Bottom line: it's nice to finally have a few non-slammed spring choices! And I look forward to seeing a few new fixed-perch strut choices, too. Freedom of choice is a wonderful thing... Happy Independence Day! Last edited by stretch; 07-04-2007 at 08:03 AM. | |
| | #111 |
| Senior STI Driver Car: 05 STi WRB Fav Mod: Driver's school Location: Columbus, OH Posts: 335
IWSTI Addict since: Jan 2006 Trader Rating: (2) | That's funny... Dude, whaddya mean it would rival softly sprung coilovers? It IS a softly sprung coilover. And there's no way it would be $600.. Your camber plate would have to be cheaper than Cusco's plate and you'd have to give away the stops. PLUS, you cannot have linear springs with dead coils. If the spring is really linear, every coil will have the same input. The only thing I don't like about your plates is that they are street-only. A race alignment isn't possible doing it that way, the hole in the top of the tower isn't big enough. I do agree, it is nice to see some little to none lowering springs coming out, they are long overdue. |
| | #112 | ||||
| Silver Member
You'd have less overall suspension travel but I think you'd still have enough. The damper and spring rates would be very similar.Quote:
| | #113 | |
| The Next Petter Solberg Car: 06 WRX STI Fav Mod: Front license plate delete Location: San Diego Posts: 931
IWSTI Addict since: Aug 2006 Trader Rating: (2) | Quote:
| | #114 |
| Junior STI Driver | I find this discussion very enlightening and I appreciate RCE actively participating in it. I have a few questions: 1. Which part of the suspension is better suited to be the first to reach maximum compression. It seems to me that the bump stops should be first, coil bind second and shock piston third. Comments? 2. Spring rates seem to be a critical factor in that stiffer springs will take more force to fully compress and weaker springs may jam the bump stops at a high speed causing a very rapid transition to HIGH spring rates. BTW: What are the limits to plastic spring rates before they break? 3. What are the objections to progressivly wound springs? It would seem that on relatively gentle roads a softer spring rate is better; and when fast rough bumps are hit, a progression to stiffer rates would prevent bottoming out [less drastic a transition from spring to bump stop rates]. I must admit that in the past, progressive springs even felt better to me when cornering hard as the rate of car angle change slows when Gs increase to max. 4. What about preloading springs on cars? This is done alot on motorcycles to get ride height maintained when the weight on the bike changes. Do coilovers enable this to be done with the STI? 5. Myles and Dan- what are coil bind and stroke specs for the Tarmac 2s. Ride height can be set without loosing stroke [good], and it also looks like preload can be adjusted too [is that correct]? What are the differences between the KW3 and TM2? Thanks again for all this interesting info. My current problem is that I have camber plates on stock springs and my fronts are about 15.5" fender-hub and rear is 14.25". Car still handles well, and I don't know what lowering it wil do to straight line high speed stability or cornering. It sounds like best way to lower my car would be coilovers though. |
| | #115 | ||
IWSTI Addict since: Jan 2006 Trader Rating: (2) | Quote:
Whiteline plates do the opposite of lowering tophats. (the KEY to the system) The only way to meet your specs is by using the only lowering plate on the market, and by using coilover sleeves, enabling you to use linear springs at your choice rates. $600 won't cover this. Even then, you'd simply end up with an $830 (more if you need helpers) set of KYB non-adjustable coilovers. I do have to admit that this still might be better than most of the sub-$900 coilovers available, but I bet it would still clunk. | ||
| | #116 |
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | I know all that, which is why I suggested the development of a totally new product: one that would probably sell for $600 as a package, have linear-ish springs, and lowering tophats. How can you possibly know that a product which doesn't exist would cost exactly $830? That's what it'd cost to do with GC Products. |
| | #117 |
IWSTI Addict since: Jan 2006 Trader Rating: (2) | Because that's what it would cost with existing equipment. It's all I have to go by. You're asking me how I can possibly know what a product that doesn't exist would cost, yet you seem to think it could be developed and sold for less than $600. You might be able to do that with KYB GR2-style shocks and cheap chinese coilover springs/sleeves, but I still think the lowering tophat would still put it over. However, do that, and you have inferior quality to just about anything out there. Might as well just throw a set of K-Sports on there.... |
| | #118 |
| Hungry Hungry Hoodscoop
Car: 32J GDFDYEH Fav Mod: Fullerton's Qrack on my car Location: Chicagoland Posts: 3,820
IWSTI Addict since: Apr 2006 Trader Rating: (23) | another confirmed case: Initially I was looking for this when I installed them (because of the extra coil). I had worse coil bind with all the signs and symptoms on my Cobbs. When i inspected the RCEs at 500miles there were no signs of coil bind. Lately i was getting thumping on harder bumps synonymous wiht bind and this thread inspired me to check. I really like these springs for the track/autox but I'm going back to Pinks. |
| | #119 |
| Senior STI Driver Car: RBP 05 2.5RS Wagon Fav Mod: Group N Lateral Link Bushings Location: Powell, OH Posts: 319
IWSTI Addict since: May 2007 Trader Rating: (0) | I just want to chime in and thank RCE for providing the actual data for the new verision of their Yellow spings. Companies that publish specs get my business. Companies who won't publish a spec a customer asks for don't get my businees. RCE, ya did good! Now when are you coming out with a setup to run at near-WRX height for us fools who see a lot of bad forestry roads so I can actually buy something grom you?! |
| | #120 |
| The Next Petter Solberg Car: 05' STI Fav Mod: Defi gauges, or TXS TBE or JDM sidemarkers...arg! Location: FairFax VA Posts: 934
IWSTI Addict since: Nov 2004 Trader Rating: (3) | Quote: Did you cut your bump stops? -Nigel This ad is not endorsed by this member. Please register or login to hide this ad. |
