| | #76 | ||||
| Silver Member
Car: Aspen 2005 STi Fav Mod: TurnInConcepts Coilovers Location: Silver Spring, MD Posts: 1,865
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Quote:
I don't expect nor want people to take my word for it though, that's hearsay. Hopefully those people will chime in themselves. Regardless, I now have some measurements. I'm told the coils of the RCE springs are 18mm thick. There are 5-6 of them vertically depending on where you measure (5.75 winds), for a total of 108mm to 90mm. That's 3.5 inches at their shortest side and 4.25 inches on their longest side. Recall from the first post that a spring needs to be able to compress to roughly 2-5/8 inches, and you see how far away the RCE springs are from where they need be. They're not even close. To give you an idea of how bad this is, the distance from the upper and lower spring perches is 8.25 inches at their absolute longest point. (I originally said 8 inches, it's 8.25.) If these measurements are correct, the RCE springs compress to 4.25 inches there, meaning that you have only four inches of suspension travel before coil bind. Frankly, I'm surprised the coils aren't completely bound at ride height. Look at the strut: ![]() I also have measurements of Prodrive springs. They use 4.5 coils at 14.8mm, for a total of roughly 74mm at coil bind at their longest part- within 4mm of the stock length and within spec. This would allow for 5.35 inches of suspension travel, more than the stock struts have even on the softer Prodrive bump stops. Unfortunately, though, they may still be inadequate for a longer travel aftermarket strut. Here's the scary part: even with a 3/4 of a coil removed from the RCE springs, (to get the springs down to 5 coils), you'd still have a spring that becomes bound at a length greater than would be required. You'd have to get closer to the 4.5 winds, not 5, and simultaneously reduce the coil diameter or use a barrel shaped spring. I imagine that the removal of a coil necessitated thinner coils, but by how much? So, the measurements I've been given indicate that even the revised RCE springs may have problems where a Prodrive or stock spring will not. It depends on how drastic and numerous the revisions were. Even if the revised design is sufficient for those on stock struts with stock bump stops, measurements will be of utmost importance for those on aftermarket struts or cut bump stops. The same goes for any other brand of spring. So, RCE, what do you say the old and revised springs compress to? You keep saying you did an extensive amount of engineering, so surely these numbers are laying around somewhere. Why not end any confusion by providing the appropriate measurement of when your springs becomes fully bound? This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by stretch; 07-03-2007 at 08:41 AM. | ||||
| | #77 | |
| Grassroots STI Racer Car: 05, Subaru Impreza W Location: Cincinnati Posts: 551
IWSTI Addict since: Oct 2005 Trader Rating: (1) | Quote:
| | #78 | |
| S204 Racer Car: '04.5 STi Fav Mod: Whiteline steering rack bushings Location: Montgomery, Al Posts: 3,073
IWSTI Addict since: Apr 2006 Trader Rating: (0) | Quote:
But since we can't do that, our only option is to trust that we're being sold a good product and be willing to purchase another set of $300 springs after we've ruined the set we've already paid good money for. RCE, if you're going to sell aftermarket lowering springs and advertise them as "designed for Ohlins replacement struts, and stock struts" I think you either need to provide bump stops for both strut applications that protects the springs you're selling. | |
| | #79 |
| Senior STI Driver Car: 05 STi WRB Fav Mod: Driver's school Location: Columbus, OH Posts: 335
IWSTI Addict since: Jan 2006 Trader Rating: (2) | That's not entirely fair... Out of all the lowering spring available for the STi, the Prodrives are probably the softest, making the inclusion of the shorter/softer bumpstops more of a simple logic thing rather than proof of better engineering. If you want Prodrive engineering, look no further than their rebadged AEM cold-air intake... Yeah, I bet they spent a LOT of time on that... |
| | #81 |
| Professional STI Racer Car: 06 WRB STI Fav Mod: Volk Racing RE30 (Diamond Black) Location: Flotsam and Jetsam Posts: 721
IWSTI Addict since: Oct 2006 Trader Rating: (0) | C'mon keep this thing going I just purchased the new Yellows and dont want my suspension all ganked up. Myles-Dan-Andrew- Someone set our mingds at ease here! Hamm er |
| | #82 | |
| Authorized Vendor Car: 2008 Pinarello FP5 Fav Mod: New Underwear after a 147mph slide into turn 17 at Sebring in the rain....still got 3rd.. Location: Columbia, Maryland Posts: 3,412
IWSTI Addict since: Apr 2005 Trader Rating: (10) | Quote:
Myles | |
| | #83 |
| Spec C Club Car: 05 STi - Black Fav Mod: No Lien Location: Ontario, Canada Posts: 1,957
IWSTI Addict since: Mar 2006 Trader Rating: (2) | I'd like to know the same for the new "regular guy" springs that I have my name on the list for - I'm paying a premium for these over the Prodrives - and I'm hoping for superior results. |
| | #84 |
IWSTI Addict since: Apr 2005 Trader Rating: (10) | This morning Myles got on a conference call with our rep and an engineer at the manufacturer and was able to get all of the vital information on the revised springs. I have the spec sheet here in front of me and everything is looking very good. The following are the specs that are relevant to this conversation: 2nd Gen. Yellows: Wire Diameter - 13.50mm Total Coils - 4.80 Solid Length - 71.34mm Blacks (Regular Guy): Wire Diameter: 13.75mm Total Coils: 5.00 Solid Length: 78.38mm We have also decided to include shortened bumpstops with all of the new springs. I hope this helps to put some of you at ease. We are still in the process of getting more information from the manufacturer as far as the reasoning for the old design, but at this point I think it is important to move forward and focus on the new design. -Dan Last edited by RaceComp Engineering; 07-03-2007 at 10:48 AM. |
| | #85 |
IWSTI Addict since: Apr 2005 Trader Rating: (10) | Also, in regards to comparing our springs to the Prodrives, you have to remember that our rates are significantly higher, and therefore it will take a lot more force to cause them to approach full bind. -Dan |
| | #86 |
| NIИja | Big thanks to Stretch for bringing up this issue, and the bump-stop issue. It also shows how great RCE is for not turning their shoulder, and continuing to grow with the Subaru community! |
| | #87 | |
IWSTI Addict since: Jan 2006 Trader Rating: (2) | Quote:
Prodrive may be softer, but their shorter stops means they have further to go to get there. | |
| | #88 | |
![]() -Dan | |
| | #89 |
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Shortened stockers? Or shorter different kind? So given these numbers that RCE just posted....thanks for that by the way....If I'm using the RCE "regular guy" spring on stock dampers, what will happen first? Bumpstops or coil bind? |
| | #90 |
| Moderator | This ad is not endorsed by this member. Please register or login to hide this ad. |
