| | #61 | |
| Authorized Vendor Car: 2008 Pinarello FP5 Fav Mod: New Underwear after a 147mph slide into turn 17 at Sebring in the rain....still got 3rd.. Location: Columbia, Maryland Posts: 3,412
IWSTI Addict since: Apr 2005 Trader Rating: (10) | Quote:
Mw This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #62 | |
Not to mention that there is a LARGE group of people who just look at numbers and dont look at let alone what "feel" is. THe only "trial and error" engineering we have done is once we had the final 5 good proto's that were approved by our engineers from the manufacture, myself and Jeff had the task of driving on all of them, one 06 and one 04. Same mods, even the same seats in the car, part for part. MAny of the reviews that came back represented what we too felt, and as I know from setting up street and race cars, what seemed to be one way doesnt always "feel" that way. In the end we chose what we chose. People like it. So as we make it better, perhaps,more people will like it. Certainly we all have those who like us and those who dont. I can accept that some of you dont like us and I appreciate those who support us. We will continue to produce good products and make sure they serve the needs of the end users. In that process, we will continue to make sure that we listen to the needs of the customers. Myles | |
| | #63 | |
So yes we have ( long before now) taken the steps to make it much better. Myles | |
| | #64 |
| Junior STI Driver | Why was the original design of the copper colored RCE spring changed? I was under the impression that only the color changed ... I did not know that one more coil was added. |
| | #65 | |
With the new springs, the decision was to go back to that, but redesigned and better with the second generation.(meaning what is almost here now having 5 coils) Myles Last edited by RaceComp Engineering; 07-02-2007 at 06:20 PM. | |
| | #66 | |
| The Next Petter Solberg Car: 05' STI Fav Mod: Defi gauges, or TXS TBE or JDM sidemarkers...arg! Location: FairFax VA Posts: 934
IWSTI Addict since: Nov 2004 Trader Rating: (3) | Quote:
Just a quick question. My stuff that I ordered about 4-5 weeks ago from yall should be in in about a week. Does this mean that I will get the newer 5 coil spring? On a side note since there is one less coil doesn't the entire spring have to be strong/stiffer to support the weight? It would be foolish for me to think that you could just cut a coil off without modifying it somehow... or is it that simple? I can't wait to get everything! Thanks, -Nigel | |
| | #67 | |
| Sold My Soul For Mods Car: '05 CGM STi Fav Mod: Track Time Location: Bethesda, MD Posts: 6,688
IWSTI Addict since: Jun 2004 Trader Rating: (14) | Quote:
-Dan | |
| | #68 | ||
| S204 Racer Car: 2006 STI Fav Mod: Recaros Location: Mahan, OR Posts: 2,904
IWSTI Addict since: Sep 2005 Trader Rating: (1) | Quote:
| | #69 | ||
| | #70 | |
| Authorized Vendor | Quote:
With materials being equal (we'll use that as a baseline so we don't get off track here). If you take a given free length between two springs and the wire diameter is the same then the one with fewer coils will be stiffer. Now, if you take that spring with fewer coils, and use a smaller diameter wire you can bring the rate back down. With that being said the net result is more compression before bind due to a) less coils and b) less material. Less coils is obvious, but lets say you go from an 18mm wire to a 14mm wire. While that doesn't seem like much just add them up 4mm difference over 5 coils is 20mm MORE of compression before bind. 4/5th's of an inch. coupled with one less coil of the original 18mm you're looking at about a net total of roughly 38mm MORE room in there. This is a good thing. Granted I didn't take into consideration the progressive winds there should still be a lot more room. Given the numbers Stretch posted you would totally bottom out the bumpstop and strut given the 38mm of additional room. I think the most valuable thing right now would be a repository of information. First being on springs showing the following: free length crushed length rate drop results of coilbind on stock struts (I say stock struts here due to needing a common baseline) Yes, I already know that rates and drops are out there as common information, but as has been pointed out there is more to it. Next we need it on struts (yes, I know there aren't a lot of options right now but that is improving): Total length full droop length full compression length body length total stroke graph if possible (maybe I should lease that shock dyno I've been looking at...) (the reason I say total length is because it would make more sense to do that and would be easy to include instead of people guessing in the future as to that number based upon stroke) | |
| | #71 | |
| | #72 | |
| | #73 | |
| Professional STI Racer Car: 05 STi OBP Fav Mod: Data Acq System Location: Warren, Michigan Posts: 798
IWSTI Addict since: Jul 2006 Trader Rating: (1) | Quote:
Also, when you say you did extensive testing you need to clarify if "extensive testing" means you guys driving the car or you guys actually runing lab tests on your springs. Very big difference there. You can't take stuff like this personal. You make money on the stuff you make so when somebody pays you $400 for the springs they would like to have ones that are properly designed. Don't take this the wrong way but you just have no excuse to take this personal. Nobody here or somewhere else made you come up with those springs and make them hit solid height. Imagine how you would feel flying in an airplane knowing that the components on it were "extensively tested" in your sense? Bottom line is that if you buy aftermarket components that are not from the OEM or Tier suppliers to the OEM you need to keep in mind that the product could have some major flaws. If not great, if so maybe the customers that purchase the product can live with them. In my opinion hitting solid height on your strut springs is very bad, especially living in pothole heaven, Detroit. | |
| | #74 | |
- Andrew Last edited by RaceComp Engineering; 07-02-2007 at 08:18 PM. | |
| | #75 | |
I would say that the bottom line is that NO product is perfect the first time it comes out. If there were no room for improvement in this industry, every company would be at a complete standstill. We have acknowledged that tweaking the design of the springs would be beneficial (long before this thread was created mind you) and we are moving forward now. I obviously don't take criticism personally but when somebody essentially tells me that my associates and I are not doing our jobs I do take that personally. This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by BoostJunkie; 07-02-2007 at 08:44 PM. | |
