Old 07-13-2007, 01:59 PM   #181
Car: '05 CGM STi
IWSTI Addict since: Nov 2004
Default Re: Another major problem found with certain lowering springs- coil bind.
Originally Posted by RaceComp Engineering
What does everyone think about having a mod delete the irrelevant posts and keeping the good stuff?
-Dan
This would be the best thing.
Old 07-13-2007, 07:09 PM   #182
Fav Mod: tracktime
IWSTI Addict since: Jun 2003
Which camber plates are on this car?
lowering or non-lowering....
Thanks snorky....that kind of thing means a lot to us.
And now....pics of Dan's car with the updated RCE V2 Yellows:
- andrew
euro is offline   Reply With Quote
Old 07-13-2007, 09:25 PM   #183
Car: '05 CGM STi
group-N's. So it would be the same as non-lowering.
Old 07-13-2007, 10:56 PM   #184
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
IWSTI Addict since: Jun 2004
Trader Rating: (14)
My car actually just has the stock top mounts on there in those pictures. Same ride height as group-n's or non lowering camber plates though.
BoostJunkie is online now   Reply With Quote
Old 07-14-2007, 08:03 PM   #185
Car: 05 WRX STi
Fav Mod: Seat Time
IWSTI Addict since: Mar 2005
Originally Posted by thrlskr
For another data point I'll look for evidence for coil bind on my Bilstein PSSS-9 this weekend.
I can confirm NO coil bind on my bilsteins.
Old 07-14-2007, 11:18 PM   #186
Car: 05 STi WRB
Fav Mod: Driver's school
IWSTI Addict since: Jan 2006
Send a message via AIM to Splash Send a message via Yahoo to Splash
OK, now that the issue is well known, admitted to, and fixed with distribution pending, I can submit these for public review...
I had been working on this for about 4 months now, since the start of the Auto-X season... What started it was a feeling I would get in sweepers where the front would "bobble" rather harshly, but the rear didn't match it's cadence. In addition, there were many gentle dips that started out gentle enough but got real harsh, real quick.
Putting the car on the rack to make sure I had installed everything right and to check the alignment, I saw something that concerned me...
THIS is the very first pic I took ...
This is the Driver's front, just sitting on ~level ground.
After looking into it further, I found evidence of heavy contact HERE:
What you can't see in this pic, is that the contact is heavy enough to squeeze whatever they use as the coating out. Those dark spots are exposed spring wire.
Finally, after disassembling the Ohlins/RCE combination so I could sell the Ohlins, I found THESE (which I think is what williaty was referring to)...
At the time of disassembly, I measured as much as I could (some I had to do twice), and basically found out that cutting the stops wouldn't matter as the spring's stack height was taller than that. This also meant my Ohlins' shorter stops were equally as irrelevant. With OEM springs, by the time you got the car down far enough to bind them, the stop's rate (even if cut) should effectively either prevent it totally, or make it so that you couldn't tell.
At the time, I thought it wisest to bring it to RCE's attention first, and allow them the opportunity, no matter how many times I was told they were fine and that nobody else complained about it, to consider my argument and perhaps deal with the issue - perceived or not. Obviously, it got more than just consideration.
Credit Schmedit, If I pointed it out first, GOOD. If I didn't and someone beat me to it, EVEN BETTER. I don't care who was the first to point it out and whatnot. For me the point is, the problem was pointed out TO THEM, and they started processing a fix early, before it made front page news. To then find out that they're replacing the fronts of anyone experiencing the bind issue, only cements that effort. That is essentially what I had hoped would happen.
Sure, I could have posted all this 4 months ago when I first started looking into it, but I didn't have ALL the information I would eventually require yet, and it would not have helped anyone if I had done so.
Suppose I had posted it all... That would have started the forum lynching WAY too early. Not only would there NOT have been a fix waiting, and LOTS of folks would have been waving their e-wangs in fury, but I've seen things like this BURY small vendors, and THEN what support would folks be getting?
I could just imagine trying to convince Tein of something like this, should they have had a similar issue...
I'm not gonna say that RCE is the only ones that would step up like this, but there are many that wouldn't have. Sure, IMO, it was a mistake (either by vendor spec or by manufacturer) that never should have showed up in production, but then, that's why they're called mistakes. The mettle is proven in the recovery of said mistakes.
It's enough for me to be confident that I'm going to replace the Ohlins with T2 coilovers at some point.
Splash is offline   Reply With Quote
Old 07-14-2007, 11:19 PM   #187
Car: 05 STi WRB
Now, compare my first pic with Dan's updated spring pic a page or two back...
Huge difference?
Old 07-15-2007, 12:11 AM   #188
Car: '05 CGM STi
I would say yes.
Old 07-15-2007, 06:48 AM   #189
Car: 05 WRX STi
Fav Mod: Seat Time
Huge difference?
This should help:
Old 07-15-2007, 10:05 AM   #190
Car: 06 STi WRB
Fav Mod: Spec C Roof Vent:Cobra Seats:Custom Cage
IWSTI Addict since: Aug 2006
I gots the coil bind BAD!
Tbagger is offline   Reply With Quote
Old 07-15-2007, 04:21 PM   #191
Car: 06 Aspen White w. Go
Fav Mod: teH Muff
IWSTI Addict since: Apr 2006
When are the new fronts going to be shipped out??
uncle lewie is offline   Reply With Quote
Old 07-15-2007, 07:36 PM   #192
Car: 2008 Pinarello FP5
IWSTI Addict since: Apr 2005
when our shipment comes in sometime this week.
Myles
Old 07-16-2007, 07:38 PM   #193
IWSTI Addict since: Jun 2006
In an ongoing effort to make sure that our customers are satisfied with our products, we have made the decision to replace the front springs free of charge for owners of the Version 1 Yellows that are experiencing coil bind. We feel that it is only fair that everyone who is using our springs has the updated version that we will be shipping from here on forward. The manufacturer overnighted us a set of the Version 2 Yellows for inspection and testing and they are now being tested on my car with excellent results. No signs of coil bind whatsoever...I will be taking plenty of pictures tomorrow. So if you have the V1 Yellows and you have coil bind issues, give us a call with your full name and invoice number (if you still have it) and we will send you out a new pair of the updated front springs.
-Dan
Good to hear. I can't find my invoice will that be a problem? Or will I still be in your computer? I bought the springs & group N top mounts from you.
Thanks
ryansti is offline   Reply With Quote
Old 07-16-2007, 07:50 PM   #194
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (14)
Thanks
Just call up with your full name and address and we can look up the invoice for you
Old 07-17-2007, 08:55 PM   #195
Car: 06 Subaru WRX STI
So... what`s the news on the new RCE spring?
No coil bind? work well with Ohlin Strut?
planning to make a strut that will work with this version of spring?
RyanLee is offline   Reply With Quote
