Old 06-27-2007, 02:59 PM   #1
Fav Mod: Car Comfort Design
IWSTI Addict since: Feb 2007
Default Bump Stops on 06 STi???
I installed some RCE yellow springs on my 06 STi last weekend. Everything went smooth and the car rides great. but something that caught my attention which confused me a bit was, after reading alot about bump stops and people cutting them to make more suspension travel when installing springs on stock shocks, I was kinda stumped when i took apart the strut assembly and i pulled off the black accordian looking dust cover sleeve to see what the bump stops looked like. There were none!! on every single strut I didnt see a bump stop. Unless Im mistaken and its the the top portion of the dust cover that i removed?... Im not sure.
Can someone clear this up for me? if that is in fact the bump stop then how the hell would anyone cut somethings thin to begin with. it couldnt have been more than a couple of centimeters thick.
Thanx in advance.
JZeezSTi is offline   Reply With Quote
Old 06-27-2007, 03:02 PM   #2
NIИja
IWSTI Addict since: Jan 2006
Default Re: Bump Stops on 06 STi???
The bumpstops are inside the strut assembly.
Old 06-27-2007, 03:11 PM   #3
Halliburton Mercenary
Car: AW GDF-D
Fav Mod: Q-Rack
IWSTI Addict since: Oct 2005
Trader Rating: (12)
Hence the inverted strut that we have.
Old 06-27-2007, 03:14 PM   #4
so how do you get to them?
Old 06-27-2007, 03:15 PM   #5
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
this has been spelled out hundreds of times.
search for it.
Old 06-28-2007, 07:40 AM   #6
Old 06-28-2007, 08:09 AM   #7
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
Old 06-28-2007, 09:34 AM   #8
Car: '06 CGM/S STI
Fav Mod: Garage (far and away)
Send a message via ICQ to [pK]Lightning Send a message via AIM to [pK]Lightning Send a message via MSN to [pK]Lightning
I won't tell you to search, you already know, but so people who search in the future finding this thread don't have to search AGAIN, it's simple. Remove the whole damn strut, pop off the spring, remove the bolt at the bottom of the strut assembly, and pull the strut from the housing. You'll find the bumpstops inside.
[pK]Lightning is offline   Reply With Quote
Old 06-28-2007, 09:53 AM   #9
Car: 06 WRB STI
Fav Mod: Volk Racing RE30 (Diamond Black)
IWSTI Addict since: Oct 2006
How do you like the ride on the Yellows?
I just ordered them.
I am coming from a kinder, gentler spring in the Prodrives....but this is my weekend car so I dont have to worry about daily commute.
I don't plan on cutting the bump stops(unless my shop says they recommend it).
I am curious what your thoughts are just in case you had a before and after review.
Thanks,
Hammer(ed)
TheHammer is offline   Reply With Quote
Old 06-28-2007, 10:01 AM   #10
Car: '05 CGM STi
IWSTI Addict since: Nov 2004
The Yellows are just fine or a daily driver. Too many posts by people who have never been on them would have you believe they are only for track cars, but that's just not the case. Very nice ride. On rough roads they can be a bit harsh, but over expansion joints etc. they are nothing to worry about. I've had mine on since November, no issues.
And I don't have my bumpstops cut.
Old 06-28-2007, 10:05 AM   #11
Car: 06 WRB STI
cool thanks for quick reply
ANy noises from them ???
Old 07-04-2007, 10:37 PM   #12
Car: 05' STI
Fav Mod: Defi gauges, or TXS TBE or JDM sidemarkers...arg!
Arrow Re: Bump Stops on 06 STi???
But isn't it better to cut the bump stops sicne there would be more suspension travel?
I am about to get the yellows installed but don't know if I should cut the stock bump stops at all...
I know rce comp says we don't have to but those that have or haven't what is the difference in ride quaility from keeping the bump stops the way they are compared to cutting them?
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 09-11-2007, 04:36 AM   #13
Car: 07 Subaru WRX STi
Fav Mod: Stage 2
IWSTI Addict since: Mar 2007
I just had lowering springs installed on my 07 sti yesterday and the guy said he couldn't find bump stops either, this explains why. I thought the car rode fine without them cut though.
doubledowntowin is offline   Reply With Quote
Old 09-11-2007, 05:21 AM   #14
IWSTI Addict since: Mar 2006
Well, since this thread has popped up again, here's my how-to with pictures:
1) Remove 14mm nut on bottom of strut
2) Observe bump stop. Cut or replace it. Prodrive's bump stop pictured (and recommended).
3) Put more grease around the inside top lip of the strut.
Then reassemble.
Old 09-11-2007, 06:15 AM   #15
Car: 06 STI, sgm
This thread desperately needs a Picard image.
TreyV is offline   Reply With Quote
