| Silver Member
Car: Aspen 2005 STi Fav Mod: TurnInConcepts Coilovers Location: Silver Spring, MD Posts: 1,865
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Well, I plotted a stock 2005 STI shock dyno (courtesy of Whiteline) to my Suspension Calculator. The stock shocks are roughly 65% critically damped to the stock spring rates, shown in the graph below. The fronts are darn near perfectly 65% critically damped, and this is considered to be ideal by most engineers. So there you have it, proof that the stock shocks are not overdamped. In fact, the rear is a little underdamped but close enough. Ergo, riding on your bump stops and/or moving to firmer springs makes you underdamped. JDM Pinks rates are such a minor increase in spring rate that the dampers are still adequate up front. The rear starts to look a bit underdamped. However, that assumes you're not riding on the bump stops, which you would be up front with any lowering springs. Once on the bump stops, the stock shocks are roughly 45% critically damped. I feel this is yet another compelling reason not to lower your car on the stock shocks, ever, not even a small amount. There's a neat little application here that will help you visualize what 45% critically damped means: http://www.engin.brown.edu/courses/e...mpedvibes.html Scroll half way down the page. Set the natural frequency as high as it'll go, then move the damping coefficient to 0.45. Click "start". Notice the secondary oscillation- that's exactly what I reported feeling months ago on my car on the stock springs, and it went away when I trimmed my bump stops. That secondary oscillation is a likely contributer to "bobblehead". This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by stretch; 06-24-2007 at 09:09 PM. |
| | #2 |
| Grassroots STI Racer Car: 07 STI UGM Fav Mod: Function is the key Location: San D'ego Posts: 594
IWSTI Addict since: Mar 2007 Trader Rating: (6) | Interesting. I've always felt that numbers don't lie...assuming, all things being equal and we've got an accurate starting base to run our equations. Now I'll quickly bow out as to let the engineering crew attack this subject. |
| | #3 |
| S204 Racer Car: 2006 STI Fav Mod: Recaros Location: Mahan, OR Posts: 2,904
IWSTI Addict since: Sep 2005 Trader Rating: (1) | I've always thought that people were missing the target a bit when accusing the stock setup of bouncing. In my experience the suspension was okay, it was the seat springs that were underdamped . |
| | #4 |
| Gold Member
Car: 05 Subaru WRX STi Fav Mod: T2s and Recaros Location: Allentown, PA Posts: 3,329
IWSTI Addict since: Oct 2005 Trader Rating: (7) | Yeah but they're overdamped the moment you hit the bumpstop, with the 1.5" of strut travel they provide, correct? |
| | #5 | |
IWSTI Addict since: Sep 2005 Trader Rating: (1) | Quote:
| | #6 | |
| Spec C Club | Quote:
Everyone should do a simple test. Drive down a road you know to be smooth as a baby's bottom and then put your hand under your rear end (palm down) and feel what the seat is doing. You'll be amazed. | |
| | #7 |
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Yes, hitting the bump stops makes the system quite underdamped. This data seems to further validates that Prodrive is the only company to have actually done real engineering when designing springs rather than relying on a butt dyno. Their very mild spring rate increase, for which they seemed to receive some criticism (even from me), now seems to be a smart decision- and they tackled the much larger issue via a softer bump stop and conservative ride height. If my data is wrong, please show me where- it very well could be. However, while I think Prodrive did the engineering, I don't think they provided an ideal solution to the problem. Any lowering whatsoever via springs is a bad idea IMO on the stock shocks, which means "lowering springs" need the assistance of other parts to make the package work. I'm a broken records saying this, but I think the best setup currently available would be the stock springs with Prodrive bump stops and RCE lowering camber plates, as that'd have even more suspension travel. Edit: no, Ground Control plates with Ground Control springs- see later in post. Speaking of, I want to thank 4banger for doing the legwork on figuring out the damper calculations. Wes, all your work appeared to be correct when I checked it, and I've obviously added parts to my suspension setup spreadsheet. Thanks a ton, man. Personally, I now think the stock shocks have some potential. Their issue is limited stroke, but a vendor could make better use of it if so inclined. It'd take four parts: 1) A camber/caster plate that adds an inch or more of bump travel 2) A redesigned spring tophat to accommodate the camber/caster plate (stock tophats would rub if raised an inch). 3) ~275lb/in linear front pretensioned ~100lbs, ~240lb/in rear springs (with dead coils). 4) Prodrive bump stops front, trimmed stock bump stops rear Without special lowering plates, such springs would raise the car half in inch- all the lowering must be done via the plates. But with the plates, such a system could trade about 1/2" of droop for bump travel and lower the car the other half inch as most people would want. The system would be only 62% critically damped, but the higher rates are a compromise of having insufficient total suspension travel. Lower spring rates require more travel which the stock struts don't have, so a balance must be struck between being underdamped and not having enough stroke. Having sufficient travel is king here and gets priority. Actually, ya know what? It just occurred to me that this is pretty much what Ground Control offers, I think- camber plates that add about an inch of travel and springs that could be adjusted to keep that bump travel. I probably would have tried that if I had this data before ordering coilovers! Such a system would cost $800 from GC and offer a lot of adjustability, both more than what I think some would want. TiC or others, is it time for you to make your own camber plates? How about some 1" lowering plates? Heck, just give me a permanent 1.5 degrees of extra camber and leave the adjustability to the bolt (allowing a range of ~0.6 to ~2.4 degrees), that'd keep it simple and cheap. Bundle them with smaller diameter spring tophats and a custom smaller diameter spring so it all fits, and I think you'll have a spring package that would give an STI excellent ride quality and handling. I dunno, maybe there's no market for such a comprehensive (and inevitably expensive) kit, but it sure as hell would be cheaper than Ohlins + camber plates to accomplish much the same thing. Racecomp was on the right track with their lowering camber plates but really jumped ship by making lowering springs designed for their non-lowering plates. Last edited by stretch; 06-25-2007 at 06:42 AM. |
| | #8 | |
I like all the work you've done on this topic, stretch, it's much appreciated. Now the only issue is that even if you can come up with a good plan to utilize the stock struts, none of this solves the single biggest problem (IMHO ) -- clunk, clunk, clunk! | |
| | #9 |
| Spec C Club Car: 05 STi - Black Fav Mod: No Lien Location: Ontario, Canada Posts: 1,957
IWSTI Addict since: Mar 2006 Trader Rating: (2) | What about RCE's upcoming "normal" springs? A slightly increased spring rate (with emphasis on higher rate increase on the rear) and a near stock ride height? |
| | #10 | ||
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Quote:
So no, I don't like any of RCE's springs. I haven't tried them, but I did try similar rates and ride heights while running Ground Control springs and sleeves. Either RCE is choosing (like all the big spring companies) to completely ignore the very important suspension travel problem or they've got some long-travel fixed perch dampers in the works (which would also be a great solution). Last edited by stretch; 06-25-2007 at 10:26 AM. | ||
| | #11 | |
| Authorized Vendor | Quote:
| | #12 |
| Gold Member
Car: 06 Subaru WRX STI Fav Mod: Ohlins struts Location: Mckinney, TX Posts: 759
IWSTI Addict since: Oct 2006 Trader Rating: (0) | If you make such a drastic camber plate you'll also have to be careful with tire clearance. After all, the more travel you give the car, the closer those tires can come to rubbing the fenders. For example, with my RCE lowering camber plates, Ohlins struts, and stock springs I have more travel than ever before and as a result in extreme situations my front 245/45-17 tires will rub under heavy compression. Granted, those oversized tires have a lot to do with that but still it's something to think about. Last edited by SWortham; 06-25-2007 at 10:35 AM. |
| | #13 |
| Gold Member
IWSTI Addict since: Oct 2006 Trader Rating: (0) | Oh, I wanted to pose a question. What about compression damping? I just wonder if a lot of the harshness of the stock struts comes from the compression side of things in addition to the limited travel. It sure would be helpful to see a damping graph of the Ohlins struts next to the stock struts. It could be that the Ohlins are far more digressive on the compression side of things. And along with the fact that you get more travel with the Ohlins, that could explain the vast improvement in ride quality. Last edited by SWortham; 06-25-2007 at 10:59 AM. |
| | #14 |
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | The compression damping is pretty similar to what many other manufacturers use and looks good to me at a glance. Heck, Koni uses more compression damping and they're still comfortable. In regards to rubbing- yeah, that can become a problem especially if you start running larger diameter tires. You've discovered the reason why all cars must have fender gap to be comfortable. Your car must be awesomely comfortable if you actually have that much suspension travel, though- to hit the fender, your car (at its ride height) would have to use more than 2" of bump stroke, I think. Nice. Ideally, you want to use as much stroke as possible, then hit a bump stop just prior to the fender to prevent damage. On my last car, I had enough stroke to allow the tire to hit the fender, but it was extremely rare in practice so I lived with it. The ride quality and performance was worth it. |
| | #15 | |
| Gold Member
IWSTI Addict since: Oct 2006 Trader Rating: (0) | Quote:
This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by SWortham; 06-25-2007 at 11:31 AM. | |
