Old 02-22-2008, 07:22 PM   #46
Fav Mod: TiC AST's - 7/6K
IWSTI Addict since: Feb 2005
Default Re: Weight transfer, spring frequency, damper, body roll calculator... and more!
Originally Posted by antonch View Post
Overall spring rate reduces when you put 2 springs in series right?
Yes, it does.
Old 02-22-2008, 07:51 PM   #47
IWSTI Addict since: Mar 2006
Stretch-
Can we add tire spring rate to the resonant frequency calculator?
In short: not easily.
I believe I've figured out how to calculate tire rates with reasonable accuracy, but the rates are variable (very progressive) and my spreadsheet is too simple to deal with that. I'd like to change the equations, but it's going to require quite a bit of work and rethinking. I've got a long list of stuff I'd like to add to that original spreadsheet, but I diverted my time towards creating a virtual 4-post shaker rig. Ultimately I think this new spreadsheet I've been working on will completely replace the original since it is much more powerful (but you better have a high-spec computer, it's very inefficient).
Unfortunately, I have been too busy to work on anything car-related for the last two months or so.
stretch is online now   Reply With Quote
Old 07-05-2008, 02:12 PM   #48
Car: RBP 05 2.5RS Wagon
Fav Mod: Group N Lateral Link Bushings
IWSTI Addict since: May 2007
Stretch, is there any way to tell your spreadsheet that I've installed the Whiteline Roll Center Adjusters (KCA313) and switched from wagon to sedan control arms?
williaty is offline   Reply With Quote
Old 07-05-2008, 06:43 PM   #49
Yes, the Whiteline RCA's raise your roll center about an inch up front (and only up front). The control arms aren't going to be too relevant to the calculations I do.
Old 07-05-2008, 09:40 PM   #50
IWSTI Addict since: Sep 2003
If you are looking a weight transfer numbers you might want to adjust the track too. There will be a change. I have an '04 and there is a change in the rear. (Motion ratio change isn't noticable.)
Web_Foot_STi is offline   Reply With Quote
Old 07-05-2008, 10:36 PM   #51
Stretch, is there a way to calculate base roll center height before the addition of the Whiteline RCA? The reason that I ask is that I'm trying to model a 05RS wagon on STi springs right now. I know the ride height, so I was wondering if you could somehow derive the starting roll center height and then I could add the 1" adjustment from the RCA to it. It didn't occur to me until just now that I have a different roll center than an STi.
Ride Height:
-FR: 15-3/8"
-FL: 15-1/4"
-RR: 14-3/4"
-RL: 14-11/16"
Old 07-06-2008, 05:00 AM   #52
I don't have the software to calculate that, no, but even if I did those wouldn't be nearly enough measurements! I bet your car has pretty similar roll centers to an STI, though. Having struts in all four corners pretty much guarantees a roll center barely above ground.
To see what measurements I came up with a year ago (I no longer have the software or measurements), see this thread:
http://www.iwsti.com/forums/suspensi...-analysis.html
Old 07-06-2008, 08:11 AM   #53
I would recommend that you go on the whiteline board and ask if they have any info. The whiteline guys there are usually very helpful.
Ride Height:
-FR: 15-3/8"
-FL: 15-1/4"
-RR: 14-3/4"
-RL: 14-11/16"
