| | #16 | |
| Senior STI Driver Car: 05 STi WRB Fav Mod: Driver's school Location: Columbus, OH Posts: 335
IWSTI Addict since: Jan 2006 Trader Rating: (2) | Quote:
If the damper itself is too short to allow this, it will be airborne (or just as useless) with very little movement of the opposite front. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #18 |
IWSTI Addict since: Jan 2006 Trader Rating: (2) | I'd say more than 1.5 and the perches will be closer to the middle of their range, giving you a better balanced travel solution. They weren't noisy, but the 450lb spring combined with spherical bearing plates makes sharp bumps harsh, but then any sharp bumps on bearing plates are harsh. The ride was plenty good for a firm street car. |
| | #19 | |
| Amateur STI Driver | Quote:
Ride and corning performance was good? | |
| | #20 | |
| Silver Member
Car: Aspen 2005 STi Fav Mod: TurnInConcepts Coilovers Location: Silver Spring, MD Posts: 1,864
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Quote:
You'd be right if you weren't running a sway bar, but even the very smallest sway bars are going to transfer the 100lbs or so of unsprung weight from one side of the car to the other. However, without a spring pushing to extend the shock, the tire would extend too slowly towards the ground (think of how quickly you can expand a shock by hand) beyond the spring's length and the added grip would still be almost nothing. Heck, you want that weight to transfer to reduce understeer mid-turn- if you didn't, then you're better off obtaining less weight transfer in the rear via a smaller sway or softer springs. | |
| | #21 |
| Gold Member
Car: 05 Subaru WRX STi Fav Mod: T2s and Recaros Location: Allentown, PA Posts: 3,329
IWSTI Addict since: Oct 2005 Trader Rating: (7) | how about not running a rear swaybar with these coilovers? |
| | #22 | |
However, ALL that changed were the coilovers vs STOCK struts and OEM springs. The bars and their settings remained the same after I took the coilovers off, alignment specs set the same, same camber plates. The bars were WL bars, 27/24, both set to full stiff Point blank, the H&R coilovers and their 450/400 springs could not keep the inside rear wheel down, while the stock struts and springs could, so at least we know that the progressive portion of the OEM rear springs are stronger than the H&R helper springs, and that the available extension length of the OEM struts was long enough to allow it. But, in the H&R's case, no amount of stiffness (as in remove the helpers and use longer mains) would have helped because the total front roll was still more than the available extension of the rear struts. Keep in mind this is not for turning, keeping the wheel down is simply a mechanism to keep the stock rear diff happy. If I could replace the diff, I would likely carry the inside rear wheel about 1/4 to 1/2" up almost everywhere. (once it's up, there is no more transfer to be had) Without fail, no matter what combination of bars, struts, or springs I've had, any solution worked successfully for keeping the inside rear wheel down as long as the available extension length of the rear strut was more than the amount of total front roll on the opposite front corner. Another good case in point, are the KW coilovers, where they have a LOT less extension than the stock struts, but have a lot more than the H&R's (or Tein Flexes), which seems to be sufficient to keep the wheel down until you use 275 R-comp tires, at which point you need to increase front bar or spring. However, in classes where you can use KW's and R-comps, you can change the diff, and that is preferred solution. | |
| | #23 |
| Professional STI Racer Car: STI Fav Mod: CE28-N Location: SFV,SO-CAL Posts: 686
IWSTI Addict since: Nov 2005 Trader Rating: (4) | How does these compare to a similarly priced coilover? tein flex rtc... This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
