Old 04-23-2004, 03:40 PM   #1
Car: 04 WRB STi
IWSTI Addict since: Jan 2004
Send a message via Yahoo to allwheelsdriven
i did this on my RS impreza and it took about 2 hrs. Is it about the same to put a perrin rear swaybar on the sti? Any glitches?
Mike
allwheelsdriven is online now   Reply With Quote
Old 04-23-2004, 04:03 PM   #2
Default CUSCO REAR SWAY BARS
it took me about 15 min on the front and about 10 min on the rear is one of the easiest things you can do.
stardust is offline   Reply With Quote
Old 04-23-2004, 08:40 PM   #3
Car: '04 WRB
Fav Mod: A working ECU...
IWSTI Addict since: May 2003
Yes it is easy, but....I did end up having a 'clunking' in the rear suspension somewhere after running my Cusco adjustable rear sway on the middle stiffness setting. Went back to stock, clunking gone! There was no visible interference, might have been inside the struts for some reason. Just take note before and after...
Old 04-26-2004, 12:45 PM   #4
IWSTI Addict since: Dec 2003
Default Show me your Need4Speed Sub Enclosures
rear was easy. didn't even jack up the car (left the suspension loaded). maybe 15 minutes total.
front; I couldn't do myself. I didn't have the proper tools and I could not get the bracket off on the passenger side, cross member was in the way of one of the nuts. major pain in the ass (for me).
2 hours on your RS? well, this install is basically identical to the RS's install, but it shouldn't take you more than 15 minutes or so. no glitches, piece of cake. You may want to research some of the issues people are having though (if you haven't yet): http://forums.nasioc.com/forums/sho...threadid=512862
DMikko is offline   Reply With Quote
Old 04-26-2004, 12:53 PM   #5
Car: 01 M Coupe
IWSTI Addict since: Mar 2004
Send a message via Yahoo to Egan
You need to drop the subframe in order to get at the bracket bolts easier. 5 bolts on each side, plus 2 up front. Just be sure to torque them correctly when you put it back. You'll also have to drop the jacking plate and support in order to get the stock bar out.
Egan is offline   Reply With Quote
Old 04-26-2004, 01:35 PM   #6
yup, that's exactly right!
something I couldn't do laying on the floor of my parking garage with my 3/8" socket set! course, I didn't figure this out until after I had one of the bolts free... then I spent a good amount of time just trying to put it back together stock, no luck, I missed the autoX the next day because half of the sway bar was swingin loose no fun..
Old 04-26-2004, 01:55 PM   #7
Car: 01 M Coupe
I'll tell you: my life got significantly easier the day I bought my cordless impact gun form Harbor Freight. Best $120 I ever spent. It made dropping the subframe quick and easy. I originally bought it for swapping wheels at the track, but it has become an invaluable tool.
http://www.harborfreight.com/cpi/cta...emnumber=46701
Old 04-26-2004, 05:57 PM   #8
IWSTI Addict since: Nov 2003
Send a message via AIM to Davidsk5018
Default Pics of me and doublej during cruise
So, if you have to leave the suspension loaded, what is the easiest way to get under the car? It is lowered, and I know there is no way to get under there without getting it up off the ground somehow. Is there some ramps you can get somewhere?
Davidsk5018 is offline   Reply With Quote
Old 04-26-2004, 06:03 PM   #9
Car: 01 M Coupe
Ramps.
I have the ones with the extension so lowered cars can actually drive on. With the rears, i usually just jack the rear end up and slide the ramps underneath.
Shot from my WRX:
