Old 06-12-2007, 11:19 AM   #31
Car: 06 AW STI
Fav Mod: BC Coilovers
Send a message via AIM to boostin04
Default Re: Pics of the BC Racing BR series non-inverted coilovers
Theres something im not understanding here... ive got these coilovers on my 06 STI, but along with these coilovers, i have 24-27mm front and rear whiteline sways and i 3 wheel up curbs and ramps, to my understanding this is normal right ? Since most of the weight of the car shifts to the side with more load when going up driveways and such right ? I dont think im 3 wheeling when cornering, how can u measure the droop travel while the cars on the ground ?
boostin04 is offline   Reply With Quote
Old 06-12-2007, 11:28 AM   #32
Wheel33tist Whore
you has no droop.
you can't measure droop travel when the car is on the ground.
easiest way is to go to a lift all 4 wheels off the ground.
and measure.
and just b/c 3 wheeling is "normal" doesn't mean it's right.
Old 06-14-2007, 11:23 AM   #33
Fav Mod: T2s and Recaros
Update:
I'm getting noise from the rear of the car over medium bumps. It's sort of a clunking noise, but not like strut clunk. I'm going to go and check to make sure things are tight, the noise isn't pronounced or loud, but worth checking up on. I do not expect any coilover to be silent. It may very well be the rear springs compressing.
Old 06-14-2007, 07:21 PM   #34
Fav Mod: Whiteline sways, ohlins coils, cusco motor mounts
Just wanted to let you know that the unsprung weight would only be half the weight of the dampers, the tops are mounted to the sprung part of the car(the chassis) and the other half is mounted to the unsprung part of the car(the hubs).
Congrats on the new suspension. Get it aligned/balanced as soon as possible. You won't believe how much better it will handle. Plus it will save your tires(I already made that $700 mistake)
neal0124 is offline   Reply With Quote
Old 06-14-2007, 07:37 PM   #35
Thanks for explaining that, good to know
I'm loving these coilovers. I need to retighten them a bit, but they've been performing way beyond my expectations. I'll be getting an alignment done next weekend as well as putting on the ALK.
Old 06-15-2007, 07:58 AM   #36
Fav Mod: a garage
Someone has dyno plots of these:
http://forums.nasioc.com/forums/show...1085379&page=9
(about mid page)
Old 06-15-2007, 08:14 AM   #37
Fav Mod: TiC AST's - 7/6K
Did anyone figure out which dyno plot is the front and which is the rear. Did anyone find out what damper setting the plots are based on?
Everyone should check out the pics of the adjustment knows almost rubbing the axles.
Old 06-15-2007, 08:44 AM   #38
Fav Mod: a garage
I would consider these but I think I need to wait and see what happens to the people who use them for autocross. How long do they last between rebuilds and how much of an issue this axle proximity thing is?
Old 06-15-2007, 09:08 AM   #39
sti robot - On the Nasioc thread, the guys with the axle proximity problem said that they were trying to 'slam' their cars. I didn't read very closely so you may want to double check that.
Old 06-15-2007, 09:18 AM   #40
I don't have axle proximity problems with mine set an inch lower than stock ride height, FWIW. It's not close, either.
Old 06-15-2007, 09:29 AM   #41
Car: 05 OBP/Gold
Fav Mod: TBE
Send a message via AIM to redlin'r
These sound like a great coil-over! How is the rust protection on these and I think we will only see with time about rebuilds. Keep posting stuff and I have subscribed becuase these are on my list of coil-overs to consider!
I appreciate the truthful remarks and review. Keep it up!
redlin'r is offline   Reply With Quote
Old 06-15-2007, 09:32 AM   #42
Car: 427Vette/04E55AMG
Fav Mod: bc racing coilovers
Trader Rating: (50)
Send a message via AIM to IMPORTIMAGE
i've had customers in canada with these for about 8 months...
so far so good...over 160 sets out there already for wrx/sti
IMPORTIMAGE is online now   Reply With Quote
Old 06-15-2007, 09:56 AM   #43
Fav Mod: a garage
I guess it wouldn't matter to me then. I'm not going for a slammed ride (yo!). I'd be going for handling + adjustability.
Old 06-15-2007, 10:07 AM   #44
Yeah, same here. They're pretty easy to adjust too. Still very happy overall with this purchase. Time will tell about rebuilds.
Old 06-15-2007, 10:09 AM   #45
hey all. i'm the dude with the shock sleeve/axel problem on nasioc. no one is trying to slam the car (yo!). i noticed that while lowering the car, one side does not allow me to go to a certain point (shock sleeve hits axel boot with minimal drop). while i'm ok with all the other corners (i can "slam" to the ground if i want).
i also have some minimal clunking (typical coilover noise) but over all i am pleased. however, i am trying to figure out the prob that i have. perhaps, controll arms, or something is bent in that area.
Superst@r is offline   Reply With Quote
