Old 06-06-2007, 04:28 AM   #1
IWSTI Addict since: Aug 2006
Default Comfortable ride in '06 sti?
hey guys.. i'm getting really sick of the bobble head in my '06.. driving on highways a nightmare and i can't really enjoy daily driving.. and i just found out koni's don't work for my car .. so i was wondering if there is another set-up i can do besides the koni inserts.. and ohlins are not an option right now because i can't afford them.. any suggestions guys?
JonKaMan is offline   Reply With Quote
Old 06-06-2007, 04:48 AM   #2
Car: 04 JBP STi
Fav Mod: All of them
IWSTI Addict since: Sep 2003
Default Re: Comfortable ride in '06 sti?
I read somewhere cutting the stock front bumpstops will increase your travel and give a little better ride quality because I guess you are riding around on the bumpstop most of the time (reason for such a bumpy ride) That may not be 100% true, but just what I read.. and also try different tires. If you are daily driving the car mostly you can get a less agressive tire with some softer sidewalls which would certainly give a nicer ride. a big portion of the ride quality is due to the re070s brick like sidewalls
option 3.... reconsider your purchase on the car. STi is not for the timid and is pretty much a streetable racecar, you cant expect a caddy like ride out of it.
Good luck
NewGenSTi is offline   Reply With Quote
Old 06-06-2007, 04:59 AM   #3
Car: 2006 STI
Fav Mod: Recaros
IWSTI Addict since: Sep 2005
Unless you have money to spend, get used to it, unfortunately. A significant upgrade to the suspension will help. But even then, a lot of the bobble comes from the highly sprung seats -- with any kind of stiff suspension, they will continue to bounce. So a proper fix requires addressing both, and unless you are very clever that means $$$.
My bobble fix was about $3100. Two thirds of that was for the Recaro Sport seats, the rest for springs, camber plates, and tops. Not the cheapest route for sure, but I can tell you that I have zero bobble. The majority of the improvement came from the seats.
Old 06-06-2007, 09:53 AM   #4
DCH
Fav Mod: Q-Rack!
Send a message via AIM to DCH
I concur.
However, with the right mods, and maybe some help from Dan (BoostJunkie) or Myles from RCE, it's possible.
DCH is offline   Reply With Quote
Old 06-06-2007, 10:57 AM   #5
approved this message.
IWSTI Addict since: Jun 2006
Fixing the bobblehead.
Partial fix 1: Cut the stock bumpstops, or install Prodrive bumpstops. That way you get more travel and the ride will improve.
Partial fix 2: New struts/coilovers. Expensive.
TRUE FIX: New aftermarket seat. There are always seats for sale here and on NASIOC. Pick one up. It's cheaper than new suspension bits (mostly).
Old 06-06-2007, 11:20 AM   #6
Car: 04 STI
Fav Mod: Koni shocks
IWSTI Addict since: May 2004
You could use the 04 kuckles and wheels then use the Koni's The Koni's are the ONLY reason I am keeping my 04 and not going to a 07 limited. Its rides so nice now I just can't believe Subaru couldn't valve thier shocks like the konis.
kinger is offline   Reply With Quote
Old 06-06-2007, 01:09 PM   #7
Car: 05 CGM STi
Fav Mod: ski boot alignment and fitting
IWSTI Addict since: Jun 2005
IMO, the Prodrive springs are signifcantly more comfortable than stock, and I also find their performance better. Note that they come with shortened bump stops for the front.
Someone on this forum rated these springs for comfort on a 1-10 scale, and I agree with their assessment.
stock springs: 1
JDM Pink springs: 3
Prodrive springs: 6
Unfortunately, I do not think there are any cheap solutions to the dampers. (I wish Koni would make an 05+ STI kit.)
Hope this helps,
J
Bootsie is offline   Reply With Quote
Old 06-06-2007, 03:04 PM   #8
Fav Mod: The Newest One!
Ive also read that the fix is in new struts and/or new seats. I went with Tanabe GF210 springs last year and It lessoned the bobble head, but it is still there. Ive gotten used to it. The STI bobble head is better than an STI with a blown rear strut.. Now that made me sick on the highway and I learned to appreciate my struts after I replaced them with some stock take offs.
I would love to go with some Ohlins, but they are out of reach for now. There are a couple companies working on aftermarket struts. Have to see when they are available
Old 06-06-2007, 03:39 PM   #9
IWSTI Addict since: May 2006
I'm almost complete with my quest of getting comfortable ride in my 06 STI
Check out these threads:
http://forums.nasioc.com/forums/show....php?t=1274294
http://forums.nasioc.com/forums/show....php?t=1279507
maramaralula is offline   Reply With Quote
Old 06-06-2007, 03:42 PM   #10
Car: 2006 Aspen White STi
IWSTI Addict since: Jul 2006
i think the bouncy feeling is fun
cusco is offline   Reply With Quote
Old 06-06-2007, 04:02 PM   #11
IWSTI Addict since: May 2007
My biggest problem with the STI's stiff suspension is when turning on rough road, I feel like my car is going to bouce to the next lane. I saved money for few months, and got the Ohlins fixed struts, and cannot be happier. Tires with softer side wall will help.
jsap13 is offline   Reply With Quote
Old 06-06-2007, 06:42 PM   #12
Fav Mod: Motor Mounts
IWSTI Addict since: Oct 2004
Simple...get some standard WRX struts and springs...
Old 06-06-2007, 07:28 PM   #13
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
IWSTI Addict since: Jun 2004
Trader Rating: (14)
Unfortunately it's tough to get a comfy ride out of the stock struts. You can make it better but they simply have too much rebound to completely eliminate the bounce. Cutting the bumpstops can be helpful but it is by no means a solution, the biggest problem is the valving. Prodrive springs or the upcoming RCE "regular guy" springs, along with some Group-N top mounts will improve the ride quality a lot, but that still leaves the struts and seats. As of now the only thing available for 05+ is the Ohlins, although we are working on changing that in the not too distant future As far as the seats, they do make a big difference as well. If you want to go the least expensive route possible with seats you can usually find a set of Evo 8/9 takeoffs for pretty cheap. They won't match the interior but they are very comfy and supportive.
BoostJunkie is online now   Reply With Quote
Old 06-06-2007, 07:55 PM   #14
IWSTI Addict since: May 2005
Prodrive springs along with Pirelli PZero M+S Tires. Very comfortable. Buying another set of tires justifies a set of aftermarket rims, of course.
Lang is offline   Reply With Quote
Old 06-07-2007, 01:35 PM   #15
Fav Mod: Driving School / Trunk swap (no attention ftw)
IWSTI Addict since: Sep 2006
SEATS!!! That'll get rid of 99% of the bobblehead, but won't make the ride any softer...just less of a headache.
mgsm666 is offline   Reply With Quote
