Old 08-26-2007, 12:56 AM   #61
Car: 05 Subaru WRX STi OB
Fav Mod: Protune by Jorge
IWSTI Addict since: Oct 2004
Default Re: Best front subframe brace?
Originally Posted by VSGTS14
bruce, does the the GT spec frame set work with ALK?
and what brace would best be suited for track purposes?
I know this is off topic, but VSGTS14, your car is HOT!
scrmblr2 is offline   Reply With Quote
Old 09-24-2007, 10:37 PM   #62
Car: Silver 05 WRX STi
IWSTI Addict since: Dec 2004
Send a message via Yahoo to import111
Ok, last few days I got this type of mod in my head. I want to keep the stock under tray to reduce drag on long straight aways. Any of these after market sub frames allow you to keep your stock under tray?
If not, how bad will the drag be without the under tray? I would think my top speed on straight aways would drop due to more air turbulence under the car. If that is the case, I am not sure this mod is right for me.
Any thoughts?
import111 is offline   Reply With Quote
Old 09-25-2007, 02:18 AM   #63
Car: 05 WRX STi
IWSTI Addict since: Apr 2005
I bought the Carbing sub-frame which is very light and good priced. Since I will be installing a full roll cage, it is exactly what I need. There's even mounting location for the stock under tray too.
Honestly, you don't really need a sub frame brace or even keep the stock one in there if you are not seriously tracking or full time racing your car. With only a VERY stiff suspension you will benefit from the stiffer sub frame brace.
Old 09-25-2007, 09:25 AM   #64
Muller Chevrolet
Fav Mod: a new 09 STi
and weight reduction, the gt spec pieces are beautiful.
VSGTS14 is online now   Reply With Quote
Old 09-25-2007, 11:23 AM   #65
I do indeed have a VERY stiff suspension setup. How ever I would like to make the car even stiffer. I track my car also. I am thinking, after market sub frame brace and TIC fender braces would hopefully stiffen things up, and take some weight off the front end with the sub frame brace.
Old 09-25-2007, 11:25 AM   #66
Car: 2007 OBP Subaru Impr
Fav Mod: Gearing in 07' STi FTW!!!
IWSTI Addict since: Sep 2006
Send a message via AIM to sti002
i would go with the beatrush lol.. but from these two. from looking at them. i like the rpm cuz it has more points towards the front of the chassis! RPM FTW!!!
sti002 is offline   Reply With Quote
Old 09-25-2007, 01:36 PM   #67
Car: 2004 STI
IWSTI Addict since: Apr 2004
I have the RPM Sub-frame brace and the TiC fender braces and there is a noticeable improvement in stiffness. I installed the RPM brace first and that seems to account for the majority of the improvement. The fender braces (at least when installed after the sub-frame brace) did not produce a detectable improvement but should contribute something.
70s-gearhead is offline   Reply With Quote
Old 09-25-2007, 03:13 PM   #68
nulla poena sine lege
Car: '08 GT500
IWSTI Addict since: Nov 2003
Any thoughts?
RPM was developing a solution for the undertray. Hopefully he will chime in here.
In regards to weight, just go with the aluminum RPM brace...it's under 10 lbs.
QuickSilverSTi is offline   Reply With Quote
Old 09-25-2007, 09:29 PM   #69
IWSTI Addict since: Aug 2006
Trader Rating: (14)
Does anyone know if the Carbing subframe will fit their own brand aluminum undertray?
Old 09-26-2007, 08:42 AM   #70
IWSTI Addict since: Mar 2006
I would hope Carbing's parts would work with each other.
The Do-Luck one is light too and works with the stock undertray. This is the one Phil uses on his Element time attack car in conjuction with a roll-cage.
I have the aluminum RPM one and it's super light. However, until James comes out with the tray for it, it won't work with the stocker.
Saabaru STI is offline   Reply With Quote
Old 03-02-2008, 04:05 PM   #71
Car: 07 Subaru WRX STi Bl
Fav Mod: APS INTAKE
IWSTI Addict since: Nov 2007
Send a message via Yahoo to manny07sti
Who sells these braces? M1 and rpm
manny07sti is offline   Reply With Quote
