Old 06-03-2007, 04:55 PM   #1
Car: 06 STI - SGM
Fav Mod: HPDE
IWSTI Addict since: Dec 2004
Default Rear GroupN Strut-Mount SQUEAK?????
Who has experienced a "squeak" from a rear GroupN mount?
Thanks,
TomK
ace996 is offline   Reply With Quote
Old 06-03-2007, 04:57 PM   #2
Muller Chevrolet
Fav Mod: a new 09 STi
IWSTI Addict since: Oct 2004
Default Re: Rear GroupN Strut-Mount SQUEAK?????
hmm you know i think i have...
cause my rear is making a lot of noises and i know the squeak appeared after the spring install with those on.
Old 06-03-2007, 09:55 PM   #3
Car: 06 OBP STi
IWSTI Addict since: Sep 2005
I've had that annoying squeek roughly after a month after purchasing the car... Now with the group-n's even more squeeky! Oh well, it's doing its thing. I've grown used to it, but it makes my 35K car feel like 10k.
Kind Regards,
Ryan
r12rex is online now   Reply With Quote
Old 06-04-2007, 01:51 PM   #4
IWSTI Addict since: May 2006
i have some sort of noise too coming from the rear left after the group N strut mounts install + coilovers, its more like a "creak" than a "squeak". The noise occurs only when i go over small abrupt bumps where the car weight shift left and right. For example: when entering a driveway. Straight line or even hard cornering, no noise.
maramaralula is offline   Reply With Quote
Old 06-05-2007, 01:58 PM   #5
IWSTI Addict since: Feb 2006
Same here, got the squeak and it's a PITA. Myles says it's the strap wrench issue on the T2 install (which I'm sure you know about) but I think it's the rear strut mount..... Ifyou got a fix Tom let me know.
And be good
Daryn
SmoothSTi is offline   Reply With Quote
Old 06-06-2007, 11:59 AM   #6
I have the RCE T2s also. Yeah and Myles told me that when you installed the coilovers, you need to use the "strap wrench to tighten the shaft". I don't quite exactly understand how you would do this. I can just let my installer figure it out, but i also want to know myself.
Old 06-06-2007, 12:06 PM   #7
Car: 2006 STI
Fav Mod: Recaros
A strap wrench looks like this: http://www.ridgid.com/Tools/Strap-Wrench
You use it to hold the strut shaft while you use a regular wrench on the nut.
Old 06-06-2007, 03:36 PM   #8
I see... thanks Rootus!
Old 06-06-2007, 07:15 PM   #9
Car: 06 STI - SGM
Fav Mod: HPDE
And be good
Daryn
Daryn,
I've no answer yet, but I'm working on it with my mechanic and Myles.
Your GroupN squeak on any particular side?
Be good,
TomK
Old 06-06-2007, 07:21 PM   #10
Car: 06 STI - SGM
Fav Mod: HPDE
Hard cornering - no noise.
Straight line - bump on right side...noise, bump on left side...no noise, bump on both sides (big expansion joint)...noise.
Noise only on right rear...from top-mount location.
Be good,
TomK
Old 06-07-2007, 10:07 AM   #11
Be good,
TomK
For me only lateral bumps make noise but the noise source is only from the rear left area of strut mount.
I hope you get this issue solved.
The design of the strap wrench by ridgid looks like it might damage the shaft of the coilover. I think the craftsman one is better. What do you think??
Craftsman
Ridgid
Old 06-07-2007, 04:20 PM   #12
Car: 06 STI - SGM
Fav Mod: HPDE
Craftsman
Ridgid
Craftsman, and wrap it around the shaft twice.
Old 06-07-2007, 09:16 PM   #13
The creaking noise is getting louder and louder to a point that i'm worried something's gonna break. I was making a left turn on a slightly bumpy road, and from the rear left you hear this CREAK, CREAK, CREAK, CREAK, CREAK, CREAK, CREAK, CREAK, so loud and obvious!!!! I'm going to bring it to my installer first thing tomorrow morning.
Ian
Old 06-07-2007, 09:47 PM   #14
Car: 06 OBP STi
This is very common...I have it right now with my Group-N's on RCE Springs. I actually had it before the install! Only the rear passenger side and on slight bumps...Anyway, I've grown to live with it...but it does get annoying at times....
Kind Regards,
Ryan
Old 12-20-2007, 09:36 PM   #15
Car: Crystal Grey 06 Sti
Fav Mod: Neg camber rocks!
IWSTI Addict since: Dec 2007
Default Don't squeak until you're squoken to
I know this issue has been covered ad nauseum on all kinds of forums.. as I have just spent over two hours reading every kind of explanation for the right rear squeak problem! .... But......
Apart from KW sending new versions of their coilovers to a number of Subie owners, I'm not sure that I have read of an actual, physical "fix."
I haven't heard the full explanation for the actual noise making either. Several customers suggested an abrasive reaction between the two metal surfaces of the top hat and the N mount but KW seemed to be saying it was a valving issue. It is apparent to me that it is a combination of both; The restrictive valving creates a minute lifting of the metal surfaces which in turn generates the abrasive squeak. This is born out in my particular situation because I have enjoyed my Tarmac 2's from Racecomp through an entire autocross season with no problems. However .... I live in North Dakota.. and as soon as our temperatures dropped below freezing the dreaded squeak raised its head! Presumably the thicker condition of the fluid within the reservoir exacerbates the slow reaction of the valving and separates those surfaces.
My main question is this; Am I doing any harm to the integrity of my suspension system? Is something wearing out that could fail under stress?
Puddlian is offline   Reply With Quote
