Old 06-01-2007, 11:37 AM   #1
IWSTI Addict since: Apr 2004
Default Rear alignment uneven?
The last time I got my alignment i found out my camber in the rear was uneven. The rear left is -1.5 and the rear right is -1.7. Since the rear is not adjustable, my alignment guy could not change it. How did this happen? He said that I could get lateral links to make it adjustable but it is probably not worth it. Anyone else have this problem?
na-STi is offline   Reply With Quote
Old 06-01-2007, 11:39 AM   #2
Car: 05 OBP STi
Fav Mod: My Right Foot
IWSTI Addict since: Oct 2004
Default Re: Rear alignment uneven?
.2 cross camber is not that bad. I wouldn't even worry about trying to reach 0 cross camber, unless it was a track dedicated car.
Lateral links would be great, but would be overkill for most. If you really want to match them, get some camber bolts. But again, I wouldn't worry about .2* difference.
RdRacer301 is offline   Reply With Quote
Old 06-01-2007, 02:34 PM   #3
What causes it to be uneven? Is more stress being put on one side or does it come from the factory like that?
Old 06-01-2007, 03:05 PM   #4
Car: 04 PSM STi
IWSTI Addict since: May 2003
The rear camber is somewhat adjustable. My shop was able to change mine from -2.0 to -1.5. This was without camber bolts - just using the slop in the system.
wi77iam is offline   Reply With Quote
Old 06-02-2007, 02:42 PM   #5
Fav Mod: Driving School / Trunk swap (no attention ftw)
IWSTI Addict since: Sep 2006
^^ really?? thats very impressive...not really sure how he/she did that. There shouldn't be that much play in the rear suspension
mgsm666 is offline   Reply With Quote
