| Junior STI Driver | I am going to get a pair of 24mm front rear sways very soon ( as soon as Andrew @ race comp ships them) And way wondering what is the best setting to have the on with stock suspension with -2 camber front -1.3 camber rear. I was thinking to set both at full stiff then reduce front if understeering or reduce rear is oversteering. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Junior STI Driver Car: Silver 04 STi Location: In da mountains. Posts: 98
IWSTI Addict since: Nov 2005 Trader Rating: (0) | Set the front to full stiff and the rear to soft. I've seen national level STis run a very large FSB set to stiff and no rear bar. |
| | #3 | |
| Senior STI Driver Car: 06 Subaru WRX STI Location: Fort Lee, NJ Posts: 307
IWSTI Addict since: Apr 2006 Trader Rating: (1) | Quote:
| | #5 |
| Gold Member
Car: 05 Subaru WRX STi Fav Mod: T2s and Recaros Location: Allentown, PA Posts: 3,329
IWSTI Addict since: Oct 2005 Trader Rating: (7) | 29mm big bar up front(ideally) 26mm for you, 24mm out back for springs on stock struts. |
| | #6 |
| Spiteful Old Codger | What it actually, actually, actually depends on is grip. Think of it like this: Case #1, your car has tires made of wood. You do a run. There ain't much grip. Case #2, your car has slicks. There is allofasudden a ****load of grip. Relative to your bar settings, the important thing is that the *relationship* between front and rear is changing along with the overall grip level. The F/R relationship for a well-prepped STU car is going to be different than for a well-prepped AS car (as if there were such a thing)... and different from a well-prepped BSP or SM car. On STU-ish tires and OE springs, you may be able to find something acceptable with a pair of 24mm bars, although you'd be much better off with more spring. On race tires, forget about it. In AS, you will want much more FSB, and probably a little less RSB. In BSP you'll want something more like 24mm in front, but then no bar in back... and something on the order of #850/#550 springs. |
| | #7 |
| Senior STI Driver Car: 05 WRB STi & 07 AW 3 Fav Mod: Invidia G200 Location: Modesto, CA Posts: 337
IWSTI Addict since: Aug 2006 Trader Rating: (2) | what size front swaybar should i go with if i have tein flexs (10kg/8kg) and a perrin 22mm rear swaybar? im leaning towards a whiteline 27mm fsb or is that too big for a 22mm rear? This ad is not endorsed by this member. Please register or login to hide this ad. |
