| The Next Petter Solberg Car: 05' STI Fav Mod: Defi gauges, or TXS TBE or JDM sidemarkers...arg! Location: FairFax VA Posts: 934
IWSTI Addict since: Nov 2004 Trader Rating: (3) | http://cgi.ebay.com/ws/eBayISAPI.dll...link:middle:us OR http://cgi.ebay.com/ebaymotors/NEW-M...QQcmdZViewItem I posted this on the RCE springs as someone recommended using one of these greases to use on the metal shaft of our struts before installing springs..to help prevent clunking..etc? Has anyone done this before? How much grease do you use?... I have never done this so I am guessing I just put grease in my hand and then put it on the metal strut body and slide it up and down so that it goes inside of the tube... is that correct? -Nigel __________________ This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Spec C Club | Links are not working, but I remember reading that you are supposed to use lithium grease. |
| | #3 | |
| S204 Racer Car: 2006 STI Fav Mod: Recaros Location: Mahan, OR Posts: 2,904
IWSTI Addict since: Sep 2005 Trader Rating: (1) | Quote:
I used general purpose lithium grease and put it inside the strut, filling the grease resorvoir near the top of the housing. You have to take the strut catridge out to get to that, but that only requires removing one nut on the bottom. I don't think the particular choice of grease is as important as having some in the first place. | |
| | #4 | |
IWSTI Addict since: Nov 2004 Trader Rating: (3) | Quote:
Yes yes, I was actually planning on doing this once I get the springs off... I read the how to change springs sticky and there is a bolt right undernethe the strut... then it says pull hard to pull it out... I was goingt to do this anways to cut the bump stops as well... Once I pull it out is there an actuall place where I would put the grease? I have never opened it up before so not sure what I am looking for.. See if that link works: http://cgi.ebay.com/ws/eBayISAPI.dll...0%3D%26fvi%3D1 Thanks, -Nigel | |
| | #5 |
| Silver Member
Car: Aspen 2005 STi Fav Mod: TurnInConcepts Coilovers Location: Silver Spring, MD Posts: 1,866
IWSTI Addict since: Mar 2006 Trader Rating: (2) | I used Valvoline Durablend Semi-Synth. It's lithium grease with moly added. I used it because that's what I already had. http://www.amazon.com/Valvoline-Dura.../dp/B0002KLBOC I've repacked my struts once and haven't needed to again (in nearly a year). Just for curiosity's sake, I took apart my shocks recently and found the insides still very slippery and filled with grease. Spraying the outsides of the struts is futile. |
| | #6 | |
So this is a no go and get the one that you chose? http://cgi.ebay.com/ws/eBayISAPI.dll...0%3D%26fvi%3D1 What is Moly? Also I just used my new impact wrench... W00t w00t! To take everything off... BTW OMG IT WAS SOOOOOOOO EASY!!!! Pulled out the strut tube... Where exactly am I putting the grease? I have to cut the front bump stops but where exactly am I squeasing it into? The rings of the bump stop, squirting it down the black tube then putting the shiny tube back into the black strut and tighening the bolt...etc? Just want to make sure I do it correctly.. -Nigel | |
| | #8 |
| Moderator | there is a seal inside the strut housing at the top. You will probably find some white-ish grease in there. I cleaned all of that out and used general purpose lithium grease. I would just buy it at any auto parts store. It should be cheap. |
| | #9 |
| Authorized Vendor | We used HP800. Why - because we had it here, it's nice and thick, and we've been happy with it. What else would work - oh, just about anything. If you don't have some of the uber $$ HP800 sitting around a good wheel bearing grease will work also. Take out the insert, clean up the old grease really good, repack the seals and such, and give the strut a light coating before reinserting. On a side note, if installing lowering springs at the same time cut your bump stops. |
| | #10 | |
Everyone is talking about seals... where are the seals... I see the bump stops that I have to cut but the silver shaft that I pulled out of the black strut doesn't seem to come apart... or does it? -Nigel | |
| | #11 |
| Spec C Club Car: 08 STi, SSM Location: Edmonds Washington Posts: 1,428
IWSTI Addict since: Dec 2005 Trader Rating: (0) | You're kidding me right? look at the mouth of the strut body, there is a seal there. It's the one people spray with WD40 in the mistaken hope that it gets rid of their strut clunk. IIRC there is also one at the bottom of the strut. |
| | #13 | |
| Moderator | Quote:
Inside the top lip of the black (strut housing) is a seal. The seal is basically 2 rubber rings with white grease (and probably dirt/debris) between them. | |
| | #14 | |
Cool, thank you! How do you completly remove all of the old grease from the inner black strut... Should I just keep pushing rags in there and pulling them out? I've completly wiped off all the grease from the silver inner strut, and cut the bump stops. Should I libberly cover the bump stops in the new grease? Thanks! -Nigel | |
| | #15 | ||
This ad is not endorsed by this member. Please register or login to hide this ad. | ||
