Old 04-19-2004, 11:37 AM   #1
IWSTI Addict since: Mar 2004
I was wondering about the front sway bar. The stock one is suppose to be 19 mm, is that right? If so, can a wrx 20 mm front sway bar can be install on a STI?
Alain
ahamel is offline   Reply With Quote
Old 04-19-2004, 03:33 PM   #2
IWSTI Addict since: Dec 2003
ya, the cusco i just ordered was the same for the wrx as it is for the STi. people are suggesting the 22mm though w/ a larger rear bar also.
DMikko is offline   Reply With Quote
Old 04-19-2004, 03:58 PM   #3
I was thinking to put a fornt at 20mm just a bit stiffer but not much. As for the rear it really need something, I got a 22-24-26mm whiteline in order at Lachute.
Old 04-20-2004, 07:08 AM   #4
Car: 04 black STI
Fav Mod: short shifter
umm.. how does the mm effect it? 19mm vs 26mm?
jrich523 is offline   Reply With Quote
Old 04-20-2004, 10:04 AM   #5
Car: 98 Impreza 2.0RS
IWSTI Addict since: Jan 2004
many suspension gurus have found that changing both sway bars to the same mm helps keep the car controllable under extreme situations... ive heard this from cobb, cusco, hotchkis, and even our own FT...
to each his own though - just MO :wink:
capaSTi is offline   Reply With Quote
Old 04-21-2004, 08:00 AM   #6
I'd like to run 20mm front and 24 or 26 mm (when require) rear. I'd just like a easy cheap change for the front one. I can get the 20 mm for 60$ CAN...
Old 04-21-2004, 03:17 PM   #7
IWSTI Addict since: Apr 2004
Send a message via AIM to KingofImports.com Send a message via MSN to KingofImports.com Send a message via Yahoo to KingofImports.com
You may want to uprade your mounts if you do 26mm, but I guess if you do not really ever utlize what the 26mm can provide, then you should be fine.
KingofImports.com is offline   Reply With Quote
Old 04-22-2004, 05:11 AM   #8
Default 2.5 sti vs 2.0 sti
I'm not really sure you need to updrade the rear mount. If I compare my old RS, they have been reenforce. Anyway it's only for thing solo 2 course, so if I need to rotate the rear, I'll be able to do it easily.
Old 04-22-2004, 06:30 PM   #9
IWSTI Addict since: Oct 2003
Default Re: Quick question! hurry answer! - coolant size
I've got the Cobb front bar only--I can't upgrade the rear and stay Solo II Stock. It's a very nice piece with good, clear instructions. It really helped flatten out the turns and feels great in daily driving. Adds a little understeer, but nothing that can't be fixed for autoxing by pumping up the front pressure and keeping the rear low...I ran 48 front/32 rear at the last event.
Slowride is offline   Reply With Quote
Old 04-23-2004, 05:35 AM   #10
Canadien rules are diferent. We are allow 2 points of mod in the class. Now, R's are 1 point, sway are 1 point each, different wheel size 1 point... So I'm still debating what I'm gone change on the car.
