| Amateur STI Driver Car: 05, JDM STI Spec C Fav Mod: ECUTEK Location: Malaysia, SEA. Posts: 39
IWSTI Addict since: Feb 2007 Trader Rating: (0) | Guys, I've been looking to purchase STI pink spring for my MY05 STI Spec C (GDBE4FH) but japanparts.com states that it wont fit my car, why is this? Check part number 1005G-018-011 and 1005G-018-012, it states "Price is for Each /Height 20mm lower, normal shape, K=45(4.6Kgf/mm) Won't fit spec C. recommended to parallel use Rear(1005G-018-012) For MY03-" This one however, did not mention anything about spec c but will it fit? Check number 1007G-020-S03 and 1007G-020-S04 it states "Price is for Each /Height 15mm lower, normal shape, K=60(6.1Kgf/mm) recommended to parallel use STI inverted Strut. *Shown Strut sell separately. *same as JDM Limited model: S203/204 Type RA / RA-R equipement." Here's the link to the site http://www.japanparts.com/db/partsli...aker=4&volkey= Hope y'all can guide me. Thanks. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 | |
| STI Driver Car: Cars Fav Mod: Exporter Location: Tokyo Posts: 202
IWSTI Addict since: Jul 2002 Trader Rating: (1) | Here's a link to the Spec C type RA-R, the Spec C model is immediately noticeable for having the roof vent http://www.japanvehicles.com/newcars..._RA-R/main.htm So, you own a Spec C Impreza; and want springs to fit????? You realise that Pink Springs are Stock on your Unit? Graham Ware Export Manager * Since 1996 * Quote:
| | #3 |
IWSTI Addict since: Feb 2007 Trader Rating: (0) | Well, no i dont realise cos its not pink. Im not driving any of those RA or RA-R. Im driving a WR Limited Spec C. I wont waste my time here posting if i knew its pink. Check out this link http://www.j-garage.com/subaru/impreza/gdb/sti.htm |
| | #4 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,523
IWSTI Addict since: Dec 2004 Trader Rating: (7) | do you have a 4 pots or brembos? are your springs black with two purple dots in the front or a blue and green dot? |
| | #5 |
IWSTI Addict since: Feb 2007 Trader Rating: (0) | I have brembos. My coilovers is black with blue springs(aftermarket from previous owner) My car is STI WR Limited Spec C, a few of my friend here driving the Spec C type RA so i know the difference between these two. Just in case you think im confused. |
| | #6 | |
IWSTI Addict since: Jul 2002 Trader Rating: (1) | Quote:
OK, the Spec C ( all Spec C's are "warmed over" by STi ) would have had Pink struts/Pink springs out of the Factory I have no way of knowing if the Spec C STi Pink springs will fit your current coilover setup If you want to retrofit the original Pink strut/Pink Spring setup your Unit was built with, that can be quoted for , and supplied STi *don't make* an upgrade to the Spec C Pink springs/struts your Unit was built with, but replacements can be supplied Spec C's have many unique parts, and a different Wheelbase to other grades of STi Imprezas It's not that Pink Springs won't fit your SPEC C; and everything to do with getting *exactly the right* Pink spring to suit your Unit, as Spec C's are Not the same as "Regular" STi's Best Graham Ware Export Manager * Since 1996 * Last edited by japanparts; 05-22-2007 at 08:03 PM. | |
| | #7 | |
IWSTI Addict since: Feb 2007 Trader Rating: (0) | Quote:
Can you quote me the price to my email? its mfadzal@electro-vest.com I need to get one for my GDE4FH, japan parts should be able to know which one fits my Spec C from that number. I just need the pink springs not the coilovers. Coilovers are stock in black colour. Let me know if you need more info. Thanks. | |
| | #8 | |
IWSTI Addict since: Jul 2002 Trader Rating: (1) | *Not Quite* GDE4FH is a generic Subaru Model Code for all their Spec C's; this doesn't show what's a Limited Model or any subtle changes that may have occurred to the specification during manufacture ie: You will also have to advise me your *Chassis number*, I'll run this, and the Model Code through the database here and let you know the Parts cost and availability, that will match the Part to your exact car Will look something like: "GDB-0012345" Where are you in Malaysia? Port Kelang? Sabah? Other? PM me and let me know Best GW Quote:
| | #9 | |
| | #10 |
IWSTI Addict since: Feb 2007 Trader Rating: (0) | PM'ed you. This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
