Old 05-21-2007, 12:24 PM   #1
Fav Mod: Driver
IWSTI Addict since: Jan 2006
Send a message via AIM to ruski
Default Front wheel bearing replacement
From what I have found I need these three pieces to replace the front wheel bearings on an 05 STi.
28316FE000, 28015AA070, and 28015AA080 I believe that is the bearing part number, and the two seal part numbers, is that correct? The bearing says it is good for a 2004-2007 STi, but I thought the 05+ STi had a different bearing, or is it only a different hub?
If those three parts are correct, is they any other parts that are necessary for the change? (I know what tools are needed, just not all the parts)
Thanks
ruski is offline   Reply With Quote
Old 05-21-2007, 12:58 PM   #2
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
Default Re: Front wheel bearing replacement
if I understand correctly the bearing should be different on 05+.
FWIW I think wheel bearings would fall under drivetrain and therefore you may get more help in the drivetrain section. might pm a mod and ask to be moved.
